With 2 steps...
Old Nov 8, 2005 | 01:06 PM
2000 Tran Zam's Avatar
Default With 2 steps...
Do you only need them with turbo applciations, or do supercharger setups also benifit from it?
Old Nov 8, 2005 | 01:09 PM
disassembled's Avatar
I think any manual trans setup that wants to get a solid launch would benefit from one irregardless if they are NA, FI, or N2O.
Greg
Old Nov 8, 2005 | 01:40 PM
BAD FNZ's Avatar
help a noob out, what is a 2 step. I've heard about it, and I've seen it used, but what exactly is it?
Old Nov 8, 2005 | 02:30 PM
NA$TY-TA's Avatar
Read this thread.... and do a seacr for Y2K HAWK and u will find everything....
https://ls1tech.com/forums/drag-racing-tech/405027-2-step-users-potential-users-need-input.html
Kyle
a 2 step is basically a device that allows you to build boost from a stop. Im not sure whether or not it puts load on your motor, but where you would normally have 2-3 psi you can get much more boost off the line, cutting your 60 ft times down a lot.
Old Nov 8, 2005 | 03:37 PM
ty_ty13's Avatar
7 Second Club
a T-brake and 2step helps everyone if there combo is setup for it...
hell i need one badly right now
Old Nov 8, 2005 | 03:56 PM
BAD FNZ's Avatar
Ok I see how that would work for an automatic car, but what about for a manual? Can't really use a T-Brake on one, and it looks like it puts a load on the engine... but I'm still confused a little...
Old Nov 8, 2005 | 05:27 PM
pontiac's Avatar
no load on motor
ok regular rev limmitler=== fuel cut, and igniton timeing cut.
two step on with clutch pushed IN== no fuel cut, JUST ignition.
you let up the clutch (dump) and it turns off. so at the starting line you hold it floored so your motor gets all the air it needs (throttle body wide open), and the computer thinks you are in WOT mode so your motor gets all the gas it needs (injecktors dumping fuel). only thing holding the motor back is spark.
and when you dump the clutch, or let off the foot brake in an auto the motor gets spark instanly (or as fast as electicity can move)
