STS Turbo with Wideband
Can anyone help me resolve my tentativeness regarding this issue. Tune set at 11.5
thanks
andy
My car's a/f was running in the high 9s with the target tune set to 11.0. You may be running very rich. I had to lean mine out considerable (software wise) to get it to 11.5.
Tommy
Tommy
My Wideband goes completely flat on the rich side on the AEM UEGO, (no numbers at all with wide open throttle and 100 wet shot of gas). I want to make sure that I am not going to blow the thing up before I make it to San Antonio to have Allen tune this thing on the dyno.
Is placing the O2 sensor after H-pipe OK?
thanks
andy
turtle and the hare
I think putting the wideband BEFORE the turbo will yield inaccurate results, as the pressure buildup in the exhaust system throws off the wideband since it is calibrated for "normal" barometric pressure.
I would try moving the wideband back, behind the turbo, and see what results you get.
Good luck!
Tommy
The pressure build-up in the exhaust system is what throws off the readings.
The wideband should go after the turbos, and with no Cats, its perfect. Just like a normal turbo car: Turbo then Sensor (then Optional Cats)
Tommy
Tommy
andy
turtle and the hare
Good luck!
Tommy
andy
turtle and the hare
