STS Turbo with Wideband
Here is my problem, everytime I go WOT my wideband shows a 10.0 all the way till I get out of it. Driving around regular it bounces around about 14.5 15.5 while going 45 mph. I have redialed in these injectors and still something is still causing too much fuel to be dumped in.
PLEASE HELP
oh one more thing I have been to the dyno only once and it was doing the same thing going to 10.0 AFR. I did manage to get 455HP 465TQ and at the time I had #42 injectors, Allen found that my COT was turned on and I thought after turning that off it fixed it. I just got the wideband installed yesterday and its still doing this.
My car would run VERY rich at WOT, and my digital wideband only showed down to "10" as the richest value. The car would also stumble at WOT, since it was too rich.
I had to make some major adjustments to the IFR table to lean it out, and now it runs at 11.0 - 11.5. However, the adjustments I made are not linear, and I do not like the way I had to get it to run "right". (2003 Z06). Anyway, maybe it is something with these injectors? I don't know...
Below are my IFR values, starting from 0.0 inHG to 23.6 inHG. Notice that at WOT, I actually set the IFR to show more flow, which is the opposite of what should happen. (ie. under boost the injectors should have LESS flow)
68.019316
64.981079
62.996924
59.400642
59.772672
60.020691
60.392720
60.764749
61.136778
61.508807
61.880836
62.128856
62.500885
62.872914
63.120933
63.492962
63.864991
Anyway, my car runs like a monster and it never goes lean, so I'll keep it this way for now.
Tommy
Tommy
There are equations to normalize the readings based on pressure, but it's usually easier to just measure lambda at a place where exhaust pressure is more "normal". (After the turbo)
exhaust pressure at high rpm. Just my experience
If so do you have hptuners and can you shoot me over a email of that tune just so I can compare them? I have been trying to get someone else that has a STS to help me out and let me compare tunes.
As for the 12 bolt I do not have one that is with the stock 10 bolt.
PS Is there anyway to tell at all if this thing is even close?
I have HPTuners and before I got the wideband he was telling me to make sure the O2B1S1 and O2B2S1 stayed around 920 at WOT and they do but right now that still doesnt help me does anyone else have a idea
If the catalyst is a "good" one with minimal pressure drop across it, there shouldn't be any measured change from a wideband across it.
If your turbo is functioning such that there is significant pressure drop across the turbine section (as in most common, engine-mounted turbos) the higher pressure on the engine side can skew the readings from a wideband O2.
Attempting to tune WOT with a narrow band HEGO for anything other than lambda=1 is just begging for broken ****.
For gasoline: Lambda = (Actua A/F ratio)/(Stoichiometric ratio)
= (Actual A/F)/14.64
It's an engineering unit used by OEM calibrators where numbers lower than 1.0 are richer than stoichiometric.
OK now lets remove the front mount and add the post-CAT STS @ 5 PSI WFO with CAT's, O-boy! So take the 5 PSI you already had at WFO pre-CAT, add the 10 PSI the STS gave at the cat exit and some MORE fuel because that's what the engine wants to live now and you see where this is going? It's no wonder a wideband wont read it correctly. I'm amazed that any CAT survives this type of environment, even though some dont.
I'm curious if Jose or TRT has seen pressure measurements pre-turbo on the STS and what they have to add?
