SPAL fan / ATI fan shroud questions
Do all of the SPAL 16" fans fit the ATI fan shrouds? Im looking into the Extreme one that flows 3000cfm. How would I wire it in to the stock wiring because as far as i know the fan only has 2 wires and there are two connectors on the car with two wires each? I know that they share a ground so that still leaves me with two wires, which one to hook up? THANKS
The Extreme will fit. I ordered some extra clips cause the current ones fit really tight and I broke one.
I hooked it up to both wires and had both relays turn on at the same time since the fan can pull up to 60 amps.
