looking for LT1 turbo dyno #
never dynoed mine. but it had gobs more power than with the supercharger, full boost was at 6 psi but I was there by 2500 rpm's, where with the blower it was only full boost at 6000 rpm's. I was running a t70 with a max lb per hr of 84 so it was good for 15 psi with out causing a restriction.
now the new engine is being built with a 9.25:1 cr on stock heads, and with the afr's I will be getting will drop it to 8:1 for a little more boost.
