Would this turbo work for me?
Old Nov 12, 2005 | 12:00 AM
blackbird345's Avatar
Default Would this turbo work for me?
T4 70mm Turbo
Garrett Internals:
Compressor:
70mm / 62 trim wheel
4" Inlet / 2.5" Outlet
Turbine:
.81 A/R
T4 inlet flange
3" VBAND exhaust outlet
I have a 99 WS6 with Cartek Heads and Cam. I want to do a rear mount turbo, is this too big?
Old Nov 12, 2005 | 12:22 AM
Public's Avatar
Yep work fine, cam might not though if it's real nasty and tight LSA. What Comp ratio with the heads?
Old Nov 20, 2005 | 08:25 PM
yeah thats a problem, its like 10.7:1 but the cam is suppose to only be mild.
Old Nov 20, 2005 | 09:06 PM
SprayedSDime's Avatar
Less LSA would benefit you if you can't decrease the static compression w/gaskets, pistons, chambers, etc. It'd lower your dynamic compression a tad which is all that really matters anyways. The problem is, the less lobe separation you fuel injected guys get, the choppier the idel is. So it'll sound really mean getting more overlap in there to bleed off some pressure. Gotta make up which is more important. You'd be best off getting some good dished pistons and having the chambers ported out a little to get more volume in there though.
Old Nov 21, 2005 | 09:23 AM
orange88's Avatar
that looks like a xs power ad. stay away from xs power
Old Nov 21, 2005 | 10:42 AM
black_z's Avatar
I think you would want to go a little bigger. Also, post up your cam specs.
Old Nov 21, 2005 | 02:30 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
How much power you want??
Old Nov 22, 2005 | 01:33 AM
just looking to get in to the 10's.
Old Nov 22, 2005 | 09:39 AM
LS1TECH Sponsor
That's more then enough for 10's.
Jose
