Finally got it running and boosted!!
Old Nov 17, 2005 | 05:38 PM
Blown408's Avatar
Default Finally got it running and boosted!!
https://ls1tech.com/forums/dynamometer-results-comparisons/410909-408-w-et-225s-f1-procharger-dyno.html
Here is my post with the dyno information.
Old Nov 17, 2005 | 08:26 PM
Bad30th's Avatar
Daaaa^6mn !
I hope you have a neck brace, you're gonna need it.
Congrats,
Rob (Bad30th)
Old Nov 18, 2005 | 06:11 AM
DarkblueTA's Avatar
Awesome numbers, Congrads!
Old Nov 18, 2005 | 07:15 AM
onfire's Avatar
Coal Mining Director
Nice set-up! Should get some killer track numbers. Which fuelpump system are you using?
Old Nov 18, 2005 | 07:45 AM
NA$TY-TA's Avatar
stock PCM??
Old Nov 18, 2005 | 10:43 AM
Blown408's Avatar
Thanks guys..
I am using a Nasty Performance race tank with a Weldon fuel pump. I think I need a little more pump though, the fuel was dropping off at about 5500.
Yes, I am still using the stock PCM.
Old Nov 18, 2005 | 02:47 PM
2000 Tran Zam's Avatar
ya, saw the numbers posted dude. Congrats on a very bad *** setup. Just crank that **** up and hold on!
Old Nov 18, 2005 | 02:49 PM
onfire's Avatar
A Weldon 600A won't support that kind of power if your are boost referenced.
Old Nov 18, 2005 | 03:40 PM
Blown408's Avatar
Yeah, I found that out. Nate assured me that it would be enough and he had others running it with 900+ HP. I guess he was wrong. I have it working right now, Allan adjusted the injectors to compensate. I guess its a good thing I insisted on the 75lb injectors over the 60s.
