Any advice to get 600rwhp with my sts set-up
Okay I basically have a stock lt1 engine with the sts kit. I already have the t-67 upgrade. I'm looking to get 550-600rwhp somewhere in that rwhp range. I really dont have a ton of money to invest into a forged stroker engine, or some good heads. I basically want to get there on a fair budget. Does anybody know what pistons,rods, cam I should go with that would defently bring me up to those numbers. There's a guy making 550rwhp and 620rwtq threw the stock cam,heads and exhuast. Any adivce or help would be appreciated. - Mike
We're getting ready to fire up a '94 Corvette that we installed a Callies stroker crankshaft in, Compstar rods and Diamond pistons. We used a Comp camshaft, I have the spec's at the shop. Topped it off with Trick Flow heads and a Holley 58mm throttle body. We're using an ATI ProCharger D-1Sc on this car, and it should be making 12 to 14 psi. With any luck we will have it up and running Monday. I'll let you know how it turns out. Bob
