sts quality
Old Nov 25, 2005 | 03:03 PM
Mike @ New Era's Avatar
Originally Posted by slow3hoe2
i would think you could just run a different tune if you have higher compression. i know of guys running 13:1 on turbo cars in classes that the huffers have a limit...spools turbo faster and ultimately makes more power.
If you are doing all the right things along with it , you can do it and make a lot of power , but I wouldn't reccomend setting up a street/strip car with 11:1 compression and then turboing it . Sure the right tune will allow you to do this , but you can run more boost , more timing , and pump gas is more realistic with a lower compression engine when turboing it . Just my .02 .
Old Nov 25, 2005 | 04:05 PM
magius231's Avatar
the guys runnign 13:1 compression plus turbo boost aren't running 93 octane pump gas like we are. Think of it this way...going from 10:1 compression to 9:1 compression will lose you about 3% power, or about 10hp on an otherwise stock LS1. However, with that 1 point drop in compression you might be able to run 4psi more throught the engine without detonating, and 4psi X about 20hp/psi..well you do the math
Old Nov 25, 2005 | 04:20 PM
TeeKay's Avatar
The best compromise I could come up with was a 9.7:1 383 and 10-12 psi with intercooling on pump gas. I got there by realizing that I had to run N/A for a while before I could afford boost. I'm happy, can't look back. Just my 2¢ also. HTH
