how much boost from a S-trim?
Old Nov 21, 2005 | 07:15 PM
1luckeyt/a's Avatar
Default how much boost from a S-trim?
How much boost can you get from an s-trim? Is 8-10psi unreasonable for a small head unit?Should I have any problems getting 430 to 450rwhp from a LT1 with longtubes and 3in. true dual setup?
Old Nov 21, 2005 | 11:38 PM
GTOLarry's Avatar
Supposedly max is 20psi. I am running 9psi max at redline and am getting 480 rwhp on my LS1.
Old Nov 22, 2005 | 08:29 AM
turbo'd stang's Avatar
I've seen Mustangs run 19psi and put 560 to the wheels. That is plenty of blower to do 450
Old Nov 22, 2005 | 09:25 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I have friends who have done 430-450rwhp with an S-Trim on LT1's, very doable. They ran anywhere from 11 to 15psi.
Old Nov 22, 2005 | 10:14 AM
m1key99WS6's Avatar
I made 533RWHP and 588RWTQ on my mustang with an s-trim. It was running around 13#'s on a 347 stroker.
Old Nov 22, 2005 | 03:16 PM
DeltaT's Avatar
I have gotten 8.5lbs after the throttle plates and FMIC on my 383, with very good heads, small solid roller (230/236, 112LSA), long tubes and full dual 3" exhaust. The blower is the V-2 SQ S-trim.
The blower hits its max rated redline (50,000rpm) when I hit about 6200 rpm, but I am overspeeding it just a bit with my engine redline at about 6500rpm.
Jim
