Turbo F-body (pics)
Old 11-23-2005, 01:41 PM
  #41
METAL MAN's Avatar
Originally Posted by NicD
What size gate is that?
It's a 44 Nic!
Old 11-23-2005, 01:55 PM
  #42
7 Second Club
NicD's Avatar
Cool, hopefully that will be big enough to keep the boost down on that GT42 to a reasonable level for that nearly stock motor. That motor is going to be pissed at what life it has left!
Old 11-23-2005, 02:03 PM
  #43
wantafastz28's Avatar
Dont say stuff like that.
Old 11-23-2005, 02:15 PM
  #44
7 Second Club
NicD's Avatar
Haha I don't mean to scare ya, but that turbo and that kit are pretty serious stuff. I am sure we can keep it down to a reasonable level so it's not breaking stuff.
Old 11-23-2005, 02:22 PM
  #45
METAL MAN's Avatar
Your set up is running a Turbonetics 42 WG correct? The 44 on Mike's car should have no problem keeping the boost creep at bay.
Old 11-23-2005, 02:25 PM
  #46
7 Second Club
NicD's Avatar
I was running a turbonetics racegate, it was a peice of **** and spiked up to 10 psi with the exhaust dump open when it was trying to hold 5 psi. Currently swapping over to a turbosmart to see if that will help some.
Old 11-24-2005, 02:38 PM
  #47
METAL MAN's Avatar
How's your car running now? You swap over to MAP yet?
Old 11-24-2005, 06:56 PM
  #48
7 Second Club
NicD's Avatar
It's running OK so far. Still trying to get the boost to stay lower and not creep, but it made 665 rwhp with only 10 psi/91 oct so far. I will be switching over to a 2/3 bar map sensor setup shortly. I put the MAF in there just to pass emissions a month ago and haven't had much time since then. Eventually I will turn it up and see what it does on race gas.
Old 11-25-2005, 06:26 AM
  #49
METAL MAN's Avatar
What spring are you running in the WG? That might be part of the problem.
Old 11-25-2005, 09:31 AM
  #50
7 Second Club
NicD's Avatar
Tried them all. Also just put the turbosmart on last night and it was actually worse. Hmmm. I wonder if this motor is just so efficient and pushing so much air that the wastegate just can't keep up under 10 psi no matter what.
Old 11-25-2005, 01:25 PM
  #51
METAL MAN's Avatar
Well, my next guess would be the placement of your WG. It's in the right location but at a 90deg. angle to the flow making it hard to bleed off pressure under WOT. What size it the tube coming off your merge for the WG? Needs to be at least the ID size you're running for a WG.
Old 11-25-2005, 08:38 PM
  #52
disassembled's Avatar
Who is going to tune the kit? Because i need someone to tune mine like asap.
Greg
Old 11-25-2005, 09:39 PM
  #53
nick97ta's Avatar
the setup looks good and it has given me some more things to look at when putting my setup together thank you for you pics.
Old 11-25-2005, 11:04 PM
  #54
7 Second Club
NicD's Avatar
Yea, I know that angle is definately a factor but others with this same setup don't have the overboosting problem I am having. The pipe going to the WG is a full 42-44 just like the gate. Oh well, I guess I will just man up and run minimum 10 psi from now on.
Old 11-25-2005, 11:09 PM
  #55
7 Second Club
NicD's Avatar
Greg
Did you get my email? I just don't have the time to go down to Tucson, I am sorry.
Old 11-25-2005, 11:38 PM
  #56
Poor guy....
Quick Reply: Turbo F-body (pics)
