Special order (quiet procharger)?
I believe you can special order your head unit for noise. One of their inspections is a noise inspection. If the head unit is too loud, they put it in a special place, where it is either reworked or sold to someone who wants a loud head unit, assuming the noise has nothing to do with faulty mechanics. I can only assume they can find a quiet head unit threw the inspection process if you order one.
LS1Tech Sponsor
I wouldnt mind a sleeper totally silent D1SC! im still searching for a good clip of a d1sc ls1 with 7-9 psi
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic36191_1.gif)
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Originally Posted by Lawnboy
I see you upgraded your STS kit for a D1-sc Procharger?
Which system do u like better
LS1Tech Sponsor
Anyone run a Rotex on ls1 f-body? Could i buy an ATI kit minus head unit and throw the Rotex on it?
__________________
LS1Tech Sponsor
Unless your on a built motor from what im understanding, about 8 psi is all youd want to run and the standard balancer and what not is fine. Once you get up i nthe boost on a built motor is when youll have balancer issues and belt slippage
__________________
I personally don't think the ATI ProChargers are very loud. I have heard much louder blowers from the top mounted positive displacement types, such as what Ford uses from the factory. Bob
![Smile](https://ls1tech.com/forums/images/icons/icon7.gif)
New for '05 with the D-1SC is one inch thicker intercoolers, helping to keep the inlet air temp's down. Bob
#32
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
