Special order (quiet procharger)?
Old Nov 26, 2005 | 07:50 PM
Lawnboy's Avatar
Restricted User
Default Special order (quiet procharger)?
has anyone special ordered a Procharger to be quiet,
Procharger told me they can play with gear lash and pitch to make it quite.
Old Nov 26, 2005 | 08:43 PM
2000FormulaMan's Avatar
Did they say how much quieter it would be?
Let us know if you decide to go with it, I would love to hear what they mean by "quiet".
I'm playing around with making a casing for the blower itself,...that should quiet it down a bit.
Old Nov 26, 2005 | 11:39 PM
Lawnboy's Avatar
Restricted User
The tech guy said that with gear lash and pitch adjustments the Procharger would be silent!
I wonder if they install diferent gears = (Pitch) like a sharper gear, not so square .
Lash is that i gues they install the gears tighter together.
Old Nov 27, 2005 | 12:41 AM
Superman09's Avatar
LS1Tech Sponsor
hmmm. let me know how this works out and maybe a clip of there silent way and normal if you could. I am still searching for a clip of an ls1 f-body with D1SC at about 7 psi. I am curious exactly how loud everyone is cracking it up to be
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Nov 27, 2005 | 08:41 AM
Bad30th's Avatar
I have the loudest P1SC I've ever heard and I love it.
9psi, MMS crank pulley and 3.6" blower pulley.
I've been told they have a testing process and because of machining tolerances they have 'loud' ones and 'quiet' ones, and that you can special order either one.
Rob (Bad30th)
Old Nov 27, 2005 | 09:14 AM
MadBill's Avatar
Most companies that sell gear drive cam sets offer 'noisy' and 'quiet' options, often charging more for the noisy. They are made exactly the same and just tested/graded for noise and boxed accordingly. Whatever floats your boat, I guess...
Old Nov 27, 2005 | 09:37 AM
lock down's Avatar
does anyone know if this is quieter than the vortech sq series? I never heard of this with procharger before
Old Nov 27, 2005 | 10:42 AM
Superman09's Avatar
LS1Tech Sponsor
Yea, id jsut like to hear a clip of a reg D1SC at about 7 psi or close so i can see really now loud it is than a clip of the quiet one........ Anyone have one? All i can find is a walk around at 12 psi, i want a little lower psi and some revs thrown in?
__________________
Old Nov 27, 2005 | 01:09 PM
Man, if you order one of those "quiet" blowers.....you have to post a video or sound clip of that.
Will it cost extra for the quiet one?
Old Nov 27, 2005 | 05:32 PM
Lawnboy's Avatar
Restricted User
No , no extra cost,
I thought there would be others that already ordered a quiet one,
Maybe its Just ATI-Procharger trying to sell me a supercharger kit,
Are they telling me what i just want to hear?
Old Nov 27, 2005 | 07:21 PM
Hey Lawnboy,
As far as I know they do test each of their Procahrgers,...and each one has a db rating. I know you can ask for one that is on the "qieter" side,...but I'm not sure how much quieter it would be. I asked them what my db was at...and they said mine was normal for the procahrger. Pretty much what MadBill had said. I don't think they could do one that is totally silent. I'm going to call them myself on Monday,...and see what they say to me. Maybe they will give me a different story. I'll let you know.
Old Nov 27, 2005 | 08:18 PM
DeltaT's Avatar
The Vortech V-2 SQ uses helical gears, which are cut on an angle and engage more gradually than the straight-cut gears. As far as I can tell, Procharger does not have a helical gear blower - theirs are all the noisier straight-cut gears. The only way they are selling you a 'quieter' version is the way that was already mentioned - they are selecting assembled units that test with slightly (1-4DB) less noise. No way will they be as quiet as the V-2.
As far as an enclosure, for a Procharger I would watch out. With its 'self-contained lubrication system' you run a much higher risk of overheating the blower with an enclosure. Air blowing on it in the engine compartment is the only way it gets any cooling.
I believe both Vortech and Procharger have painted themselves into a Marketing corner: Vortech by its refusal to consider A2A intercooling (which is always more efficient given the proper sized IC, except for drag racing), and Procharger by telling people that not having to punch a hole in the oilpan is worth a lot, when in reality, the lubrication is worse than if it were pressurized and drained back into the pan.
Jim
Old Nov 27, 2005 | 08:53 PM
Lawnboy's Avatar
Restricted User
please call them and see what they say,
I wonder if they really check gear lash and pitch?
Old Nov 27, 2005 | 09:10 PM
Lawnboy's Avatar
Restricted User
F this , i think i am going to just get a paxton Novi 2000,
Helical cut gears, and uses a pressurized oil system,
High quality quiet supercharger that can support 1,000 HP
I heard one on a 98 mustang 4.6 4 valve cobra , sounded awasom, nice smooth gear and air rush sound.
I would of course have to have a custom mounting bracket made up, pulleys etc, but worth it,
i al ready have the ATI-procharger LS1 F-body Twin intercooler set up, just need a head unit to push boost through it.
Old Nov 27, 2005 | 10:35 PM
Well, let us know how that goes. I would be curious to see that type of Set-up.
Old Nov 27, 2005 | 10:54 PM
Insomnya3AM's Avatar
Louder the better in my book. If this thing is going to be on my hotrod I want people to be scared. Very scared. As in blowing down the street with pedestrians ducking and looking around.
Old Nov 28, 2005 | 03:37 AM
MOLESTER's Avatar
quieter is better in my book. i love the look on someones face when they think thier rolling up on a "stock" car and when they take off you take off harder than they would have ever imagend.
Old Nov 28, 2005 | 09:19 AM
boosted99camaro's Avatar
about 2 years ago I had a mustang with a procharger psc1 and it was loud and sounded great.I was spinning it fast 14psi.I just put a dsc1 on my camaro 7psi and its not loud at all.you can hear it but barly.I love it and it will get louder when I up the boost.
Old Nov 28, 2005 | 09:40 AM
Lawnboy's Avatar
Restricted User
I see you upgraded your STS kit for a D1-sc Procharger?
Which system do u like better
Old Nov 28, 2005 | 10:01 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
All the Novi 2000's I have heard were not super quiet.
I think the ProChargers are louder than the Vortechs.
My YSi is noticeable but my exhaust is pretty loud.
