2 step explanation?
Old Dec 6, 2005 | 07:20 PM
dementia's Avatar
Default 2 step explanation?
Was reading in another thread where someone said to get a good launch on a manual turbo car you'd need a 2 step. Can someone explain what a 2 step is and what it does?
Old Dec 6, 2005 | 07:27 PM
longrange4u's Avatar
Ask Y2KHawk.... he builds them.
The 2-Step makes you engine miss causing un burned fuel to detonate in the exhaust spooling the turbo up... I think... Again ask Harlan (y2khawk) he built mine.
Old Dec 6, 2005 | 07:34 PM
NA$TY-TA's Avatar
Search works really well...................... watch...........
Old Dec 6, 2005 | 07:36 PM
black_z's Avatar
It is basically a 2nd rev limiter that you use at the starting line to build boost, the 2 step cuts out spark, that allows you to put a load on the motor, and build more boost at the line.
Old Dec 6, 2005 | 07:42 PM
dementia's Avatar
Thanks for the replies so far, keep em coming. Dont assume that I havent searched already. I found lots of threads concerning 2 step issues and some of people wanting to buy a 2 step. Didnt find one that said what it was or how it worked.
Old Dec 6, 2005 | 07:44 PM
NA$TY-TA's Avatar
https://ls1tech.com/forums/showthrea...ghlight=2+step
just enters 2 step in the search........
Old Dec 6, 2005 | 07:52 PM
quicksilverado's Avatar
You set the 2-step to desired rpm. Stand on the brake and engage 2-step, then floor the gas pedal. Once the preset rpm is reached it will maintain said rpm and only 1 bank of cylinders will get spark. This helps build boost. When you let off the brake all hell breaks loose. It eliminates the need to try and watch rpms and boost while watching the tree.
Old Dec 6, 2005 | 07:56 PM
dementia's Avatar
cool thanks, i actually came across 2 of those threads in my search but didnt take away much from them. They hint at what its capable of but dont really explain what a 2 step does. Are 2 steps mostly for extreme turbo apps or would one benefit from one running on low boost for the time being?
Thanks quicksilverado, so what do you do with the clutch pedal if your gassing and braking while the 2 step is doing its thing?
Old Dec 6, 2005 | 08:10 PM
black_z's Avatar
2-steps can be beneficial to anyone. They are extremely nice for turbo setups though, so you can leave the line with more boost.
Old Dec 6, 2005 | 08:27 PM
In a manual I believe the 2-step works off the clutch instead of the brake.
Old Dec 6, 2005 | 09:20 PM
DanaliHD's Avatar
isn't harlan in the process of revamping the 2step? i thought i read somewhere that he was re engineering it to work better or something
Old Dec 6, 2005 | 09:36 PM
dementia's Avatar
thanks for the responses guys, and yea i think i read somewhere that he was reworking it
Old Dec 6, 2005 | 11:21 PM
Korben's Avatar
Can you do a two step on an automatic car???
Old Dec 7, 2005 | 02:36 AM
Aaron's 00 TA's Avatar
Yes you can.
Old Dec 7, 2005 | 09:33 AM
y2khawk's Avatar
I'm redoing the packaging, adding a couple features, etc.
And like was stated above, it's an igntion based revlimiter that is user adjustable. Can be activated by your choice of inputs, transbrake, foot brake, clutch, etc.
Turn it on, and you can flat foot the throttle while maintaining a constant and adjusable RPM.
Good for consistant launch RPM, building some boost with a clutch/turbo car, quicker spool or limited rpm with an auto/turbo car, same for a blower car, you pick
Old Dec 7, 2005 | 11:00 AM
Korben's Avatar
I've got the MSD DIS-4 PLUSthat has a two step on it........Do these work okay and will it work off of the foot brake?
Old Dec 7, 2005 | 06:56 PM
DanaliHD's Avatar
be sure to let us know when you have some ready to go. I'll most likely want one
Old Dec 7, 2005 | 10:39 PM
MIGHTYMOUSE's Avatar
i found this on google, maybe u should try a simple search first.
Two Step Video
DVD Only - $29.99
An excellent program for beginners that walks you through everything you'll need to know about the Two-Step. Made popular by the movie, "Urban Cowboy," the Two-Step is a fast traveling dance with many turns. In the Two-Step, dancers move counter-clockwise around the perimeter of the dance floor to the hottest country music on the market. The basic step is similar to an ordinary walking step, but the footwork timing is quick, quick, slow, slow. Over the years, the Two-Step has evolved into a challenging and exhilarating series of movements around the dance floor. This DVD is organized for success as it starts with the basics of lead and follow dancing, then it walks you through the basics of Two-Step, then through the most popular and most important easy, leadable patterns and turns for navigating around the dance floor. All steps and patterns are demonstrated in a split-screen format and taught in logical step-by-step sequences, building naturally on each other. Shawn Trautman has been a coach and mentor to numerous World Champions as well as countless social dancers since the early 1990's. Shawn welcomes people of all shapes, sizes, or ability to his classes. His broad experience in both dance and Advanced Learning Techniques makes his methods of instruction innovative, easy, and fun. If you're ready to learn and have fun, the Shawn Trautman's Learn To Dance Series is the way to go. 55 mins. (2005) DVD-Region 1.
Old Dec 8, 2005 | 12:07 AM
dementia's Avatar
LMAO so its more like a raindance thing that makes the turbo spool on launch? 30 bux ionno. Speaking of which, what do 2 step setups usually go for?
Old Dec 8, 2005 | 04:15 AM
reocamaro's Avatar
I can understand some of the badgering dementia's getting but i'd like to thank the people on here that aren't giving him a hard time because I've been wanting to know what two step is and just haven't been able to find the time to do a search on it. Where can I go to find about 2-step for automatics? Would I need an after market torque converter to get the rpm's higher?
