tang or on center
Old Dec 7, 2005 | 08:26 PM
KAOS's Avatar
Default tang or on center
which is better. i have heard tang creates less backpressure, is that true. i have a t74 oncenter and have the opportunity to get a tang housing. should i do it, its a great deal. and will it fit right, going from one to the other. any input would be great.
Old Dec 7, 2005 | 08:27 PM
KissMySSo1's Avatar
Tang ownz
Old Dec 7, 2005 | 08:30 PM
93formto98T/A's Avatar
I'd also like some sound input on this subject as well. I chose to go on-center but I don't know what the real differences are.
Old Dec 7, 2005 | 08:47 PM
ddnspider's Avatar
Tangential flows better and less backpressure.do it!
Old Dec 7, 2005 | 08:57 PM
2000 Tran Zam's Avatar
we talkin the poon-tang?
Old Dec 7, 2005 | 09:02 PM
..........if you like "doing" turbos then yeah. lol
Old Dec 7, 2005 | 09:26 PM
KAOS's Avatar
lets keep it civil now. so if i had an oncenter t74 would a tang housing work and would i be able to tell a differecnce. like i said the deal i am getting is unbeatable if it will work.
Old Dec 7, 2005 | 09:30 PM
onfire's Avatar
Coal Mining Director
Better make sure that you have clearance with the tang housing as it will change the turbo orientation. That's why you cant use a tang housing on the old Q.M.P. kit.
Old Dec 7, 2005 | 09:33 PM
ddnspider's Avatar
it changes the clocking of it
Old Dec 8, 2005 | 05:10 AM
KAOS's Avatar
well i no longer have the q m p kit. im getting a new custom one that locates the turbo infront of the crank pulley. i have set my rad up some to allow for a little extra room. jut wondering if it was for a t76 would it still work with a t74?
Old Dec 8, 2005 | 08:18 AM
anyone have a picture of a "tang"? What exactly is it?
Old Dec 8, 2005 | 10:02 AM
camcojb's Avatar
The tangential will definitely make more power. I'd do it but realize that if the headers/manifolds are setup for on-center then the turbo housing may now hit something. If clearance is good the tangential housing is a lot more efficient. May not make a huge difference, but definitely will be a difference.
Jody
Old Dec 8, 2005 | 03:23 PM
KAOS's Avatar
well the kit is in the process of being made so, i can do what ever i want but i just need to know if it will work. i mean i will the guts of an old on center t74 go into a tangetial housing any thoughts
Old Dec 11, 2005 | 08:17 AM
Lasershop's Avatar
If it is the same trim then yes. The tangetial flows better but I have seen many setups that make a very sharp turn at the turbine. Makes it sort of a wash between the two if you ask me. On center is much easier to fab especially with twins.
Old Dec 11, 2005 | 08:20 AM
Lasershop's Avatar
More rare to see a pic of an on center housing on this forum.
