Octane Question
Old Dec 8, 2005 | 02:12 PM
nz12's's Avatar
Default Octane Question
Being as how some of us have to live in california and can't get above 91octane at the pump. Would it hurt anything to put a coupla gallons of 100 race gas with every tankfull? It is a turbo ls1?
Old Dec 8, 2005 | 02:40 PM
longrange4u's Avatar
Nope... wouldnt hurt. Make sure its unleaded or it will fowl your o2 sensors
Old Dec 8, 2005 | 02:49 PM
nz12's's Avatar
thanks will do!
Old Dec 11, 2005 | 08:32 AM
EPP's Avatar
EPP
Torco makes a great octane booster that we use. All of our customer's who have purchased it have found it to work really well. Bob
Old Dec 11, 2005 | 11:27 AM
Hitman1's Avatar
What's the minimum recommended octane fuel for superchargers/turbos ?
Old Dec 11, 2005 | 02:13 PM
Depends on your compression ratio... the higher it is the higher your octane must be.
Old Dec 11, 2005 | 02:32 PM
black_z's Avatar
If your running boost you need a good tune, tune your car for whatever is readily available to you.
Old Dec 11, 2005 | 04:20 PM
Zombie's Avatar
Minimum octane you should run is as high as you can get, well if you like lots of boost anyways.
I often run leaded fuel in my car, but I have no cats and some denso lead friendly O2's. I just recently found some 110 octane in my area for around $6 gallon. I can get 100 leaded for under $3.00/gallon so I run that stuff quite often for having some fun.
Having a methanol kit kicks butt too, ice cold intake temps and the addition of 140 octane =
Old Dec 13, 2005 | 12:26 AM
GTOLarry's Avatar
Run an alkycontrol system. Get octane when you need it. Methanol has 100+ (123 if 100%)octane rating and also adds additional cooling to the charge. You can buy it from VP fuels in 5 gallon pails. Just installed mine and am awaiting tune. I should be able to get an extra 20 plus be able to do continuous back to back runs. I live in California too, this is the way to go. Why burn 100 when you are cruising, plus summer heat won't slow you down.
