getting ready to drill oil pan
Old Dec 8, 2005 | 06:13 PM
Dr.x's Avatar
Default getting ready to drill oil pan
and I'm scared s**tless. I have a phamspeed t70 kit and never did anything like this do I use a 3/8 npt drill bit,where is the best place to drill the pan at? where do I tap in for the return line I'm new to this but have very good mechanical skills so any info or pics would be greatfull just to get a visual on where to do this. please hook a brotha up
Old Dec 8, 2005 | 07:14 PM
KAOS's Avatar
every body says take the pan off. but i have drilled and tappen one with it on. dunno about that. but go to the drivers side of the pan and just drill and tap as high as you can. im not sure about the size of the drill bit but if you have the tap it has a recomended size on there. and are you wondering about the feed line to the turbo? the place every one uses is above the oil filter. not sure what its called but its held in with two little bolts. just take it off, drill it and tap it as well. some one will chime in with the size of it. good luck
Old Dec 8, 2005 | 08:09 PM
Assassin's Avatar
take the extra time to drill&tap w/ the pan off, when you drill it as carefully as possible you'll be frightened at how much shavings still go inside, its not worth it, your gonna need to match up your drill w/ the tap and fittings your useing, what size are they? do a search on install pictures for ls1's, I know there's some good photo's of where everything goes...
Old Dec 8, 2005 | 08:28 PM
LS1SpeedAddict's Avatar
I saw an episode of Trucks where Stacy installed a supercharger with the oil pan on. Im not sure exactly what he used but he put something on the drill bit so the metal shavings would stick to the bit. I think it was jsut grease. I would deffinatly research it.
Old Dec 8, 2005 | 08:36 PM
KissMySSo1's Avatar
plan on pulling out the motor if the pan comes off
Old Dec 8, 2005 | 08:37 PM
Wet 1's Avatar
grease
Old Dec 8, 2005 | 08:44 PM
Eric Bazan's Avatar
On my brothers car (frcefed98), We didnt have to pull the motor out to remove the oil pan. We unbolted the motor mounts and lifted the motor up as high as we could. It didnt slide right out or slide right back in, but we got it on and off with the motor in the car.
Eric B
Old Dec 8, 2005 | 09:11 PM
StoleIt's Avatar
NKAWTG...N
I tapped my pan with it on the car. Bought some spray on glue stuff and slobbered it all over the drill bit. Just take your time. Drill some, clean it off, spray more on. Also had a shock vac on the entire time. Then I changed my oil twice. Haven't had any problems.
Old Dec 8, 2005 | 11:48 PM
METAL MAN's Avatar
I personally pull the pan, not worth the risk just because it's the easy way out. Drop the K-member and jack the motor up a little, not that big of a deal. Make sure you place the fitting high as possible/close to the mounting rail.
Old Dec 9, 2005 | 06:44 AM
KraZy's Avatar
I did my oil pan this weekend......but I took it off. I could not believe the shavings that would have gotten into the pan if I had not. Granted I did not use grease, but I wouldnt chance it.
Old Dec 9, 2005 | 07:04 AM
SINISTER's Avatar
i pulled my pan
undo motor mounts raise engine drop k member down and pan will drop right out!!
time consuming but well worth it
you will have all the room to take your time and drill it right and tap it right..
i still wish someone made a steel pan for f-bodys so you can just drill and weld the fitting to the pan.
Old Dec 9, 2005 | 07:15 AM
chris's ws6's Avatar
See if you can just remove the oil level sensor and use that instead of drilling into your pan. Thats what I did when my kit(incon) went on. It sets off the check engine light but that can be taken care of by ls1 edit and just check your oil every 1,000 miles to make sure it isn't low.
Old Dec 9, 2005 | 07:27 AM
KraZy's Avatar
The oil level sensor is too low for a good gravity drain.
Old Dec 9, 2005 | 02:47 PM
Dr.x's Avatar
well the one good thing is I bought an oil pan from a buddy for 50 bucks and will just swap it out this way if I screw it up I get a second chance. I just don't trust drilling it while its on but that's just me. now all I have do is figure out what sizes to drill them thanks guy's this forum rules
Old Dec 9, 2005 | 02:56 PM
Assassin's Avatar
you could take it to a good welding shop and they can weld the aluminum, I had to do that w/ a few other custom aluminum parts, but didnt think of it when I did my pan..
Old Dec 9, 2005 | 03:21 PM
PAGregSS's Avatar
Come one, man! We've got a lot to do to get that kit on. Drill away and bring that car up here!
Old Dec 9, 2005 | 05:20 PM
Dr.x's Avatar
I'm trying its all the little things that are killing me I just found out ralph is up grading me to a bigger intercooler for being patient(which is pretty cool) so now I have to get a battery relocation kit from jegs. like I said little things
Old Dec 9, 2005 | 06:39 PM
KraZy's Avatar
I used a bulk head AN fitting.
Old Dec 10, 2005 | 01:08 AM
METAL MAN's Avatar
I weld them
Old Dec 12, 2005 | 07:12 AM
SINISTER's Avatar
Originally Posted by METAL MAN
I weld them
you make a steel pan?? or you weld the fittings to the casted alum one??
