Clutch for FI guys?
Old Dec 10, 2005 | 02:54 AM
SStolen's Avatar
I'm using a Spec Stage 4. It drives better than SPEC Stage 3 and handles more power. 700+rwhp on slicks and no problems.
Old Dec 10, 2005 | 10:02 AM
ddnspider's Avatar
Originally Posted by Frost
That stg5 squeals like mad though, there's no denying that.
what do you mean it squeals,like when u engage it?
Old Dec 10, 2005 | 11:36 AM
Zombie's Avatar
Yup, you will get a nice chirp.
Old Dec 10, 2005 | 11:37 AM
JMBLOWNWS6's Avatar
Spec 3F
Old Dec 10, 2005 | 02:52 PM
Fullthrottledan1
Guest
Posts: n/a
textralia. Havnt driven it yet with the new turbo. 370ci/GT40-88/6 speed in a truck. hopefully i didnt make a bad decision...
Old Dec 10, 2005 | 03:34 PM
V8_DSM_V8again's Avatar
You cant beat a dual disk...
I am currently running a Mcleod sintered iron on a SSG flywheel in my DSM...
Its been great even at 600+ hp... You V8 guys dont know how hard we are on clutches... Reving to your turbos spool point then slipping the clutch ever so carefully so you still pull a 1.5 60 or so but dont kill the driveline...
It will shred a mere mortal clutch system or blow a trans when using one with eratic engagement..
I love that clutch... Best high HP single disk I have ever driven... At lower powerlevels and or applications with a bigger clutch disk there are less aggressive materials... When you are trying to get 600 hp thru a 8" disk and slip it consistently at 4k rpm its the best...
Old Dec 11, 2005 | 12:45 PM
SELLSZ06's Avatar
Has anyone tried Exedy, I heard its pretty good. It should be @ $1300+. I got Cartek but I only have 520Rwtq.
Old Dec 12, 2005 | 01:39 PM
jv_Z28's Avatar
Originally Posted by 93formto98T/A
I believe the spec 5 holds 1200flbs of torque and I think the spec 3 is 750-800. From what I have heard the spec 3 is much more DD friendly than the 5 but I had no choice.
There's no way a spec 3 is supposed to hold 750-800. I was making 600tq. and 554hp on a new spec 3 and the clutch only lasted a few thousand miles. And the spec 3 and 5 feel virtually the same on the street.
Old Dec 12, 2005 | 02:39 PM
Slowhawk's Avatar
LS1Tech Sponsor
A SPEC 3F wouldn't hold our 680hp car.It was switched with a stage 5 and that holds great.
Exedy- no way it will hold.
Have a Mcleod dual behind the 770hp car but not enough miles/passes to tell.
Also got a new SPEC dual disk setup sitting here waiting to go into PUREVL's car.It looks like it will hold a ton of hp
