Powerdyne missing Parts?????!?!!!
Old Dec 10, 2005 | 12:27 AM
LastBlack02SS's Avatar
Default Powerdyne missing Parts?????!?!!!
So, I bought a powerdyne kit from a member on the forums. He claimed everything was there and even included a pulley. The pulley doesn't fit and is so big it would barely make 4 psi if i was even able to put it on. I also looked through the install instructions and I guess I need to remove the stock fans and put aftermarket ones in? Is this true? Because what I bought from the member didn't have fans! Help me out. I'll also probably be posting in other sections with updates of the install listed in sig.
Old Dec 10, 2005 | 02:20 AM
Looking for some help. Anyone know if I need aftermarket fans for clearance? Also, do i have clearance for a b&m tranny cooler?
Old Dec 10, 2005 | 08:21 AM
ALZ28's Avatar
Default clearance
you will need new fans if its the same as my LS1 kit, which came with 2 push & 1 pull fan. I have mocked up intercooler & trans cooler and push fans
send me you email address on alz28@tiscali.co.uk and I will get pics to you, the files are too big to upload to this site
Cheers Al
Old Dec 10, 2005 | 08:23 AM
AndrewB's Avatar
You sure the pulley your looking at is not the replacement tensioner pulley? And yes you are suppose to get 3 fans. 2 pushers and a larger puller. If you don't have the manual you can find it on their site.
Old Dec 10, 2005 | 10:29 AM
White_Hawk's Avatar
If it is the fans from powerdyne, they are junk anyways. I ended up going with to Spal 12" pushers and a 13" puller. It was about $400 worth of fans, though.
-Geoff
Old Dec 10, 2005 | 01:29 PM
dans91's Avatar
i went with spal pusher fans and that was it, it worked just fine for me, but putting a puller on the other side is not a bad idea, and i was going to do that but i sold the (partial) kit also. I would say this, got to summit, get the THIN spal pushers, and put them in FRONT of the ac condensor/ radiator to push through. Hook them up to the regular wires for he OLD fan setup. It isnt that hard, but if you search you will find a post from JRIOS with pics on how to set up the fans. My setup was awesome, but make sure you put a FMIC on that powerdye cause if not, you will get INSANE heat temps at your manifold. After i put my FMIC on, i noticed GREAT gains!!! Good luck and i am like a powerdyne specialist so PM me if you need any help ok!
Dan
Old Dec 11, 2005 | 03:24 AM
Thanks for the advice. If you look in the sig, I've got a twin ati intercooler setup going in with this kit so i hope it turns out ok numbers wise. Does anyone have part numbers for a fan setup? I just want to make sure I have the exact right part.
Old Dec 11, 2005 | 06:08 PM
dans91's Avatar
stand by, i will get it for you ok
Old Dec 11, 2005 | 07:25 PM
dans91's Avatar
i used this one from summit racing equiptment
http://store.summitracing.com/defaul...5&autoview=sku
Hope this helps yah out some. I bought the whole thing just cause it came with wire to relocate your fans from the back of the radiator to the front of the ac condensor.
