first tuning session of new setup
Old Dec 12, 2005 | 01:55 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
By reducing cylinder pressure by increasing overlap, is that what you mean?
Old Dec 12, 2005 | 01:56 PM
Tiago's Avatar
yes, I believe that is what he is saying.
Old Dec 12, 2005 | 02:09 PM
LS1Tech Co-Founder
I'm wanting to learn from this point... I'm not going after you guys on this point by any means. But I see Slowhawk and other advocating small grinds, even Z06 cams. Wouldn't those cams be along the lines of a stock 99 cam?
I'd be very interested to see what you picked up just from a cam swap. I'd go for a 224/224//114 something like that... It would be a clear change from the cam you have now. A 215/215 would have more intake duration than what you run now but not much more on the exhaust.
Old Dec 12, 2005 | 02:16 PM
Tiago's Avatar
yea I agree John, can someone post specs on a stock ~03 Z06 to compare with mine? they don't seem to have a problem using that cam.
Old Dec 12, 2005 | 03:16 PM
NA$TY-TA's Avatar
Im interested in this also......
Kyle
Old Dec 12, 2005 | 03:22 PM
White.Lightning's Avatar
.............Dur In. Dur Ex. Lift In. Lift Ex. LSA
'01 Z06----204----211----525----525----116
'02 Z06----204----218----551----541----117.5
Hope this helps
Andy
Old Dec 12, 2005 | 03:46 PM
Tiago's Avatar
my cam: 209/198 .500 .500 119.5
new z06 cam:204/218-.551-.541 117.5
one thing that stands out is the exaust duration difference.
Old Dec 12, 2005 | 03:51 PM
ddnspider's Avatar
just crunched some numbers incase no one else did..........that stock 99 cam has -35.5 degrees of overlap......thats alot for a turbo setup.both Z06 cams are ~25 degrees overlap.the cam PSJ posted would be much better having -4 degrees of overlap.plus the duration would give you more peak hp as well as more lift to let more air in.
Old Dec 12, 2005 | 04:07 PM
Tiago's Avatar
damn, thats brutal
220/220/114 or 224/224/114 ?
I guess I would upgrade pushrods and retainers while Im at it too so I can rev it since those cams will want to rev. Im surprised the stock pushrods are loving life
Old Dec 12, 2005 | 04:14 PM
ddnspider's Avatar
yeah that stock cam is killing you
it took me months to decide on a cam which ended up being a 226/222 115+3 thats -6 degrees of over lap.quoting Jose on FI.com overlap should be anywhere from ~-8 to +2 degrees on a turbo setup is a safe bet.i could see you picking up 40hp with the right cam....and thats ~$8/hp............. seems worth it to me.
Old Dec 12, 2005 | 04:15 PM
Tiago's Avatar
thats good info
Old Dec 12, 2005 | 06:22 PM
  #32
cablebandit's Avatar
http://www.rbracing-rsr.com/comprAdvHD.htm
i used this calculator. You need to know the intake closing point. I think stock 99 is around 31 deg abdc. I could be WAYYYYYYY wrong here all together but that was MY opinion on your results. Look at some of the big guys running 112lsa cams and such. Even Dave Inall of Incon infamy advocated Harlan switch to a 215-220 112lsa cam back in the day when he was on a stock motor to help make the same power he was on race gas, with 93 octane.
Old Dec 12, 2005 | 08:05 PM
  #33
ESR's Avatar
ESR
LS1TECH Sponsor
Default ......
I am by no means an expert I just think that the lsa is way to high if the 119 is correct for a stock cam I thought it was more like 117.5 but I could be wrong. If you notice speed inc is running some of their turbo cars on 113 lsa's probably for that very reason. I had never encountered this problem till tiago's car. I tuned mine but I had meth from the get go,cam and heads. Hes making probably like 700 dyno jet which is what most people go by. I believe that tiago could have ran about 13 or 14 # with pump gas and say a 114 due to the drop in dynamic CR which I am barely learning about. The main difference would be the lsa on a ls6 cam which actually cablebandit did run at one point.
Old Dec 12, 2005 | 08:59 PM
  #34
ddnspider's Avatar
in a LS1/LS6 manual i have it lists all the cam specs for Y,F(including ls6) bodys and trucks.thats what it said.I check the values white lightning posted for the Z06 cams and it was the same other than slight variances in the lift(.004 diff lol).So i believe the LSA is correct.that is very high which is why ive wondered about that LPE cam with an LSA of 121
Old Dec 12, 2005 | 09:55 PM
  #35
LS1Tech Co-Founder
"my cam: 209/198 .500 .500 119.5"
I like to write that as 198/209 .500 .500 119.5" otherwise some folks might think it's a reverse split. In any event, why not try a Speed Inc 225/225/113 cam, they seem to work great.
Old Dec 13, 2005 | 05:54 AM
  #36
V8_DSM_V8again's Avatar
I like what I see in the comp LS1 XR259HR.
-2 degrees overlap at .006" lift...
206/212 on 112 LSA..
Cam card
http://www.compcams.com/Technical/Se...mber=54-408-11
Old Dec 13, 2005 | 07:30 AM
  #37
Tiago's Avatar
Im actually leaning towards the thunder 224/224/114 cam. Im not going into this motor again anytime soon so I'll throw in a set of AFR 225's too while Im at it. Not doing this right now unless I have to, still don't know if I'll have to pull the heads.....
Old Dec 13, 2005 | 08:26 AM
  #38
ddnspider's Avatar
V8_DSM_V8again- the overlap is much better but the gains wont be as much as the cam that he's looking at,hes going to want more duration as well as more lift,especially if he gets the AFR's to take advantage of the extra flow.
Tiago-i think your on the right track...what do you have for a tranny and what are you planning on shifting to?
Old Dec 13, 2005 | 10:20 AM
  #39
Tiago's Avatar
I'll shift it at 6800 or so after the H/C. I have a stock T56 with a spec stage 5 clutch right now, plan to stay that way for a while. Till it dies.
Old Dec 13, 2005 | 11:11 AM
  #40
Well the lSA on that cam helps to make up for less duration and I have been runing that cam on the computer with AFR 225's..
You dont need alot of intake duration with those heads and FI.. There is also the issue of when the valves open and close in relation to the pistons timing as opposed to just total duration.
Its a split with a little more duration on the exhaust side still a smaller cam. I think the exhaust side is just right too.. Not opening to early as to loose some of a turbo engines more degrees of power on the power stroke and hits a pretty good sweet spot on the exhaust valve close point too.
I'm looking for a 6000 rpm hp peak... Actually I concentrated on huge low and mid tq and ended up with a 6000 rpm hp peak...
