highest comp. for FI and 105 octane
Old Dec 20, 2005 | 11:17 PM
camrsz's Avatar
Default highest comp. for FI and 105 octane
Whats the highest comp. ratio to run with 105 octane fuel on an FI engine.
Lets say the engine is a 348 cid ls1 and will have a max boost of 30psi
In theory an engine at 9.5:1 would have more power then an engine at 8:1 at x amount of boost. I know this is pretty general but just thinking out loud.
Old Dec 20, 2005 | 11:26 PM
V8_DSM_V8again's Avatar
Not if x amount of boost is 30psi it wont. At 7-10 psi for sure...
In theory the engine at 8:1 would make more power at 30psi because you could actually run 30psi at 8:1.
Assuming its 105 octane E85 alcohol fuel blend 8:1 will be pretty good...
Wanna boost alot drop the compression...
All the old school first generation mitsubishi's making big power on the stock turbo and bottom end all had 7.8:1 compression from the factory.
Mainly Cylinder pressure determines the ignition/pre ignition point.. Take a 9.5:1 and a 8:1 engine run them at the max boost level each can still run a good timing curve on.. The 8.1 will handle alot more boost with the same fuel and approzimate timing curve.
The cylinder pressures will be close to the same but the 8:1 is sqeezing a larger volume of air down to the same pressure.. More air = more fuel = more power...
On forced induction its the effects of dynamic compression and how many lb/min of air you can flow.
Old Dec 21, 2005 | 05:31 AM
Slowhawk's Avatar
LS1Tech Sponsor
Matter's if it is a Turbo or Supercharger. Turbo -you want a lower compression like 8-1 or 8.5-1 for that much boost. With a supercharger we have run 11-1 compression at 24lbs of boost but this is with c-16.
Old Dec 21, 2005 | 08:53 AM
camrsz's Avatar
Why does it matter if its a turbo or supercharger?
What if its a 3.3 twinscrew charger?
On that 11-1 engine did it have a cam with some decent duration on it?
thanks for the replys
