turbo gauges
Old Dec 22, 2005 | 09:12 AM
LSONE's Avatar
Default turbo gauges
so I'm thinking that my best bet would be to go with fuel pressure, boost, and i'm going to get a wideband. My question is, which types of gagues do you guys thing look the best (pewter t/a with black interior) and also which ones are the most accurate? what are you using?
Old Dec 22, 2005 | 09:25 AM
ddnspider's Avatar
its really all a matter of opinion.Black gauges always compliment a black interior,and you ll need an electronic fuel gauge so no fuel comes in the cabin,but you may wanna try posting this in the appearance section.
Old Dec 22, 2005 | 11:01 AM
will62085's Avatar
those are things youll want to keep an eye on, but remember you also want to moniter EGT (pyrometer) and because of the added motor head, oil temp...i plan on running wideband, eboost 2 (fits in a guage pod), oil temp, boost, egt, and fuel pressure
Old Dec 22, 2005 | 11:10 AM
LSONE's Avatar
Where are you going to put all of those gauges? I was going to stick with the 3 gauge pod pillar and be done with it, but i would love to have several different gauges aswell. On a side note, what part of marietta are you from? I grew up in kennesaw, and actually would have been one of the first classes to graduate through KMHS if i hadnt moved to FL.
Old Dec 22, 2005 | 11:43 AM
will62085's Avatar
i dunno where there goin...ive got an lt1 car with the different interior, so probably 3 on the pillar and two in the cd case place...grew up near roswell, now i live out in kennesaw and im at school at southern poly tech
Old Dec 22, 2005 | 01:32 PM
ddnspider's Avatar
Thats a bit overkill for a street car.Ill be running a fuel pressure gauge,Eboost2 and an aeroforce tech gauge...and possibly a wideband as well
Old Dec 22, 2005 | 04:09 PM
BirdmanLS1's Avatar
A wideband being? im not quite familiar with guages and what they do... lol, what is a wideband?
Old Dec 22, 2005 | 04:27 PM
ddnspider's Avatar
It monitors your air fuel ratio ALOT more accurately than an a/f gauge and normal oxygen sensors.Do a search on it in the diff sections or on ebay.It makes it so u can keep a close eye on whether or not your running lean.
Old Dec 22, 2005 | 04:34 PM
V8_DSM_V8again's Avatar
There is my recomendation for the wideband...
I dont bother with EGT gauges...
I have been know to use probes on standalone EMS systems and datalog EGTs...
Once you go wideband the EGT probe takes a back seat but is'nt useless...
Old Dec 22, 2005 | 04:44 PM
LSONE's Avatar
I am getting the XD-1
Old Dec 22, 2005 | 05:05 PM
Its nice.
I am probably not going to run their gauge... I'll have a mini ITX motherboard and VGA built into the dash.... I'll just use the EMS software to display things.
There are alot of things you can do.. http://www.mini-itx.com/projects/ice...ult.asp?page=4
I am NOT copying this but running a bigger display and flush mounting it.
http://www.cartft.com/catalog/il/437
For fuel pressure I am going to get a autometer sender and wire it to the EMS and display the pressure on the screen..
Old Dec 22, 2005 | 05:16 PM
KAOS's Avatar
now that gauge is the small one not the bigger of the two correct?
Old Dec 22, 2005 | 05:31 PM
Yes..
Attatched is an example of a standalone "dash" screen...
There are different skins and you can change what it displays and the layout..
Old Dec 22, 2005 | 06:21 PM
ddnspider's Avatar
when i get the cash ill prolli be going with the LC-1 wideband with the small square gauge....itll fit very nicely in that little square opening in the dash below the stereo.
http://www.dynotunenitrous.com/store...?idproduct=150
Old Dec 22, 2005 | 07:49 PM
Ferocity02's Avatar
I always though white gauge in a black interior looked nice. I went with the white face gauge cluster also to match. I have the boost gauge for sale if your interested.
Old Dec 22, 2005 | 07:58 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
One more....
Old Dec 22, 2005 | 08:18 PM
black_z's Avatar
Im going with a wideband, fuel pressure (electric), and leaning toward Eboost 2.
Old Dec 22, 2005 | 08:24 PM
ABeasst's Avatar
I've got wideband, interceptor, boost, and fuel pressure
Old Dec 22, 2005 | 09:10 PM
You can set it up for any ECU input... STD or auxillary.
Wishfull thinking on the VVT from a 6.2 graph but its just a PWM operated device so aftermarket control should be easy...
Looking at about $300-$500 for a touch screen depending on size then what ever Mini ITX computer you want to build... IMHO cool as hell and worth it..
Old Dec 22, 2005 | 09:56 PM
Slowhawk's Avatar
LS1Tech Sponsor
I ussually recommend full sweep fuel,boost/vacuum and the Dynojet wideband.Not a fan of digital A/F gauges.Find them hard to read while pushing 650+rwhp down the road.
