View Poll Results: What would you pay for a 100% complete kit, thats it.
$5,000
19
28.36%
$6000
25
37.31%
$7000
11
16.42%
$8000-10,000
12
17.91%
Voters: 67. You may not vote on this poll
POLL: TT kit for the F-Body
Old Dec 22, 2005 | 09:17 PM
V8_DSM_V8again's Avatar
Originally Posted by XJGPN
When did they start making on-center T3 housings?
I have seen them.. There are so many different produced by garret just for x company variations... Garret made mitsubishi bolt pattern on 2g DSMs etc..
Off topic but mitsubishi turbos factory on SyTY's and some Scoobie Doos. There are alot of variations.
Check this odd ball out.. Nissan T3 housing
http://www.redz31.com/pages/turboupgrade.html
Old Dec 22, 2005 | 09:57 PM
69firebird's Avatar
there are alot of different turbos that can be used, i just want to see someone do it
Old Dec 22, 2005 | 10:02 PM
What does the incon housing look like when layed out like the above pictured ones?
I dont think Incon had anything special made they just got a special made for x car company by garret components that just happened to fit.
Old Dec 22, 2005 | 10:20 PM
XJGPN's Avatar
It looks very similiar to a standard T28 housing, but they are different. Both Compressor cover and Turbine housing were custom. The CHRA was an off-the-shelf garret part.
Old Dec 23, 2005 | 11:03 AM
Frost's Avatar
Here are some small pics of the Incon setup:
Attached Thumbnails POLL:   TT kit for the F-Body-8e_1.jpg   POLL:   TT kit for the F-Body-22_11.jpg   POLL:   TT kit for the F-Body-ae_1.jpg   POLL:   TT kit for the F-Body-ae_11.jpg   POLL:   TT kit for the F-Body-cc_11.jpg
Old Dec 23, 2005 | 06:02 PM
Geo.'s Avatar
8-10K, but only if you could get a C.A.R.B. E.O. and keep A/C.
Old Dec 23, 2005 | 06:06 PM
Quickin's Avatar
A TT or a single T kit that doesn't keep A/C is pretty much a waste of money in my opinion, keeping A/C is the only way to do it right.
Old Dec 23, 2005 | 07:34 PM
slow's Avatar
you can't get CARB certification on a TT kit for the LS1 due to the locaton of the factory cats.
Ryan
Old Dec 23, 2005 | 09:12 PM
Ryan
I would'nt say you cant get it just cant without having a replacement cat system to go with it that has a carb number..
OEM's with TT and standard models have two different cat systems.. The TT car needed some tricks to get the cats up to temp quick to keep the EPA happy.
Old Dec 23, 2005 | 09:15 PM
peter@aps's Avatar
In order to obtain a CARB EO for an aftermarket twin turbo system the original factory cats must be retained in the original factory cat position.
Peter
Old Dec 23, 2005 | 09:25 PM
Peter
While that may fullfill a technicality for CARB even then I'm not sure they would pass the EPA cold start test...
Companies like Audi have had to come up with ways to get even those little precats to get hot quicker on turbo models. They just dont get up to temp as quick with the turbine in the path..
Old Dec 23, 2005 | 10:05 PM
  #32
Geo.'s Avatar
Ryan
You are probably right, though this was one of Dave Inall's (broken) promises with the Incon kit. Not sure what the differences are, but the Incon Mustang kits did succeed in getting a C.A.R.B. number somehow. They are listed on the air resources board website. I am probably in the severe minority, but the C.A.R.B. sticker would be a deal maker for me.
Old Dec 24, 2005 | 07:42 PM
  #33
slow's Avatar
5.0 mustang factory cat locations were in such a place where they could be retainded with a turbo kit.
On the 2000+ F-cars, both cats are so far up on the motor, that I don't see any way to retain it, possibly on the 98-99 cars, the factory passenger cat could remain in the same position.
All car manufacturers have compromises in the calibration to get the cats to lightoff quickly. Without going very far into the technical specs, they need to lightoff a 70 degree ambient temp cat to 600 degrees in 20 seconds, higher RPM startup for the initial start times, as well as spark retard to push heat into the cats are just part of the equation.
Ryan
Old Dec 25, 2005 | 11:22 AM
  #34
Geo.'s Avatar
Interesting! I had never seen a requirement for lightoff time vs temp spelled out like that. When I did a web search on the cold vehicle start I didn't really find much info. The beauracracy involving this is tough to wade through.
Pretty sure that the Incon spec for the catted y-pipe had the passenger side in the stock location, and the drivers side was moved a little, but not far (pretty much right on the drivers side turbo). Not sure how many ran that setup though, probably not many. The passenger side is way further from the manifold than the drivers, so maybe there is some slack in the original factory spec.
Makes me wonder if Incon knew they wouldn't pass all along, or if they had something else up their sleeves. Guess we'll never know.
Sorry for the thread hijack.
Old Dec 25, 2005 | 04:22 PM
  #35
One thing that would work would be a electronic solenoid piggy backed on the WGA.. Bump the wategate full open on cold start..
Old Dec 25, 2005 | 04:55 PM
  #36
mahhddgtp's Avatar
I'd pay $5,500-$6,000 for an incon-like kit that keeps A/C, P/S, etc etc and had turbos like the GTBB-37's
Old Mar 16, 2007 | 01:43 AM
  #37
Quickin's Avatar
APS kit is an Incon-like kit, less than $6K.
Old Mar 16, 2007 | 01:52 AM
  #38
mahhddgtp's Avatar
This post was from the end of '06
