Hot cam with turbocharger??
how much boost are you running? and do you have any numbers (dyno, or track)?
Get something on a 115... but then again, you knew that was coming.
Its a big cam..
I am looking at running a comp 206/212 on 112 but that little of duration has no overlap.
That said, the HOT cam has -1 deg of overlap at .050". The cam that I'm running with my turbo set up has +2 deg of overlap at .050". I've seen successful turbo cams with anywhere from -8 deg overlap to +18 deg everlap, so I don't think your 112 LSA HOT cam has too much overlap.
That said, the more boost you run, the more specific-to-turbo's your cam needs to be. For instance, if you were running 2 psi boost with 4 psi backpressure, any ole' NA cam would be fine. However, if you're running 30 psi boost and 60 psi backpressure, the cam might look a little different. At only 5 psi, not enough has changed in the motor to require a specific turbo cam. For instance, compare these cams:
Your HOT cam:
218/228 - 112
Proven turbo cam for 355 cid and 22 psi boost:
218/218 - 114
Not too much different, eh?
Leave the cam alone. You won't gain more than 10 rwhp.
You should focus on improving other area's, like downpipe, intercooler, raise the boost, etc. . . I wouldn't bother changing the cam until you get in the 20+ psi range.
What kind of turbo is it, anyway?
192/196 - 106 (stock)
206/206 - 106
214/214 - 112
210/205 - 112
210/210 - 112
204/214 - 112
218/226 - 112
Not too many turbo Buick cams are on a 114 LSA. Also, note the lack of consistency.
Too much LS1 cam theory is based on 1927 text books
Tuna, at what lift is the 280/272 duration taken at?
Mike
My new 370 iron block motor is using a z06 cam.
Any data on this? More cfm at the same psi = more power.
If you are pushing a combo to make a lot of power, I'd really consider a set of aftermarket castings like ET Performance, AFR, or AllPro. Thicker deck means better clamping force.
I might think this is true on ls1's with great flowing stock heads, but on an lt1, lt4 you should see a noticable gain, not a great gain, but a noticable one.
