Help me pick a mild blower cam
Why the P and not the D....and are going with Alky as well
I love it! It has just enough lope to be noticable but nothing over the top! Great power down low which is exactly what I wanted out of the cam.
Mike
you can go with a 218/224 cam, that'll give you the grunt you want with a perfect idle.
as you go 224 duration and higher the powerband shifts upward to the higher rpms.
you can go also maybe try a 220/224.
Mike
I just need more practice and I think it will run bottom 11s as it sits on a 1.7xx 60ft. The car also needs a retune, I did a pulley swap and I think when I pulled timing and added fuel I threw the tune a little out of whack!
I have a CC solid roller but I'm not running as high a boost as you will, so I went with a 230/236 on 112LSA. It idles smoothly at 750rpm, and revs easily until the cam + boost runs out around 6500. CC makes some nice solid roller lifters and you can have them grind any Xtreme Street Roller lobe profile(s) onto any LSA for less than $400.
They only need adjustment about every 2nd oil change (10K miles).
Jim
I really wish people would quit spouting that "114 is best for superchargers and turbocharger" without knowing the context and reasoning behind it. The stock Turbo GN cam is on a 106 as are some of the aftermarket Turbo GN cams.
In your duration range, 112 is fine.
