Oil feed line restrictor
No internal restrictor on my GT42 just a hole bigger than the -4an feed line itself
J
I think i'll order this and the -10an drain flange as well.http://cgi.ebay.com/ebaymotors/F7-T3...9380QQtcZphoto
J
Cold idle still smokes when warming up- don't know if it was left over or even if it was oil smoke.
Normal driving is fine.
WOT,don't really know since I was trying to keep the car straight but when I looked back after it looked pretty clear.
There is still some smoke on high rpm decel which I figure is the oil since the wideband is showing 14-1 A/F.
Guess I'll try a smaller jet and maybe adjust the return line.
J
J
Chris
Other than that the car goes good at 10psi
The poor 03 Cobra found out
Is it possible the bearing seal has already been slightly compromised from the high pressure/volume?
