Who has the advantage?
Old Dec 26, 2005 | 03:27 PM
Slow Z28's Avatar
Default Who has the advantage?
Single or Twins in the Extreme Modified class?
Looking to set up a car for the class. Are they pretty well evened out at this point, or does one have a distinct advantage over the other?
Old Dec 26, 2005 | 03:56 PM
nitrorocket's Avatar
That would be a good question for Kenny Dutwieler or someone at his level. I think MOST people are biased to what they have with no actual comparison between the two.
With that said, go with twins, It will look faster!
Old Dec 26, 2005 | 04:28 PM
NA$TY-TA's Avatar
Dont set your plans in stone yet...... some of the rules might be changing
Old Dec 26, 2005 | 04:35 PM
smokinHawk's Avatar
yes rules havent been set and if there is going to be a series is still in debate.
but as of last year the twins could slightly outpower the single
Old Dec 26, 2005 | 04:38 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
In current configuration, 60's will outpower the single setups. Also since the rules are generic alot of tricks can be done
Jose
Old Dec 26, 2005 | 05:51 PM
Slow Z28's Avatar
Jose
Jose would be called for those tricks That I was sure of.
The question was just kind of generic. I know what path I want to take. It sucks if the rules are changing. I think if you kept the rules the same for a second year, it's more inviting. Although i would like to see carbs allowed cause i want to do a blow through... just cause... haha.
Old Dec 26, 2005 | 06:13 PM
smokinHawk's Avatar
not sure if the rules will change or not yet, still in debate.
most likely some rules may change but more likely in outlaw.
Old Dec 26, 2005 | 07:14 PM
fash00's Avatar
im hoping to see them allow the large frame turbos in the EM class possibly with a weight penalty
Old Dec 26, 2005 | 11:14 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Problem with allowing T6 flange stuff is that it can make 200 more hp over the T4 stuff with single setups... it gets tricky.
Old Dec 26, 2005 | 11:25 PM
engineermike's Avatar
So what are the quickest cars running on a T4 turbo? Probably going 88 mm right?
Old Dec 27, 2005 | 12:47 AM
fash00's Avatar
still limit it to 80 mm wheels
Old Dec 27, 2005 | 11:17 AM
smokinHawk's Avatar
82mm was the old limit
Old Dec 27, 2005 | 11:38 AM
LS1TECH Sponsor
An 80 with T6 flange would be competitive. An 82mm T4 unit is not.
Jose
Old Dec 27, 2005 | 11:49 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Jose, you feel that an 80mm/T6 is equivalent to the twin 60mm/T4 setup? How are you comparing the two, just curious.
Honestly, we are targetting a 9.0 ET for that class, to keep entries competitive. You should be able to reach that goal with either setup as the rules are currently written. If cars start going quicker, they will need to carry more weight to slow them down. Yes, that is brutal, but that is class racing for you.
Tony
Old Dec 27, 2005 | 12:08 PM
LS1TECH Sponsor
Yeah, looking at the GT47-80 and new S80, it will make around 1300-1375hp depending on the unit chosen. A pair of standard 60's with p-trims on T4's will support 1200-1250 easy, and trick units will support even more (~1300+hp easily).
As for 9.0 target, that can be done with alot less unit when the car is purposely built.
JZ
Old Dec 27, 2005 | 12:36 PM
Just using simple geometry, it would take a single 85 mm to compete with twin 60's.
Old Dec 27, 2005 | 01:14 PM
LS1Tech Co-Founder
A T4 flanged 88mm could make 1200hp. NMRA Drag radial allows a 85mm T6 flanged turbo and the class record is like a 8.3@161mph for that kind of setup. I think that is at like 3300 raceweight too.
Old Dec 27, 2005 | 01:24 PM
LTLHOMER's Avatar
Go single because twins aren't allowed in many other classes besides ls1tech.
Old Dec 27, 2005 | 01:43 PM
fash00's Avatar
Please allow up to 80 T6's i know theres a few of use out there
Old Dec 27, 2005 | 03:32 PM
NA$TY-TA's Avatar
Wether or not they do im still going to keep my T6 flanged unit..... they should allow it but do like a 100lb weight penelty or something like that..... my car was built fr me and not a class... if it fits... its does i gues and ill race in it next yr. If not ill still be racing.....
Kyle
