Boost Gauage Directions
Old Dec 29, 2005 | 12:25 PM
JD_Z28's Avatar
Default Boost Gauage Directions
Does anyone know where I can get directions on how to install a boost gauge on a ls1 with an STS kit. Thanks
Old Dec 29, 2005 | 01:51 PM
JD_Z28's Avatar
bump,bump^^
Old Dec 29, 2005 | 02:08 PM
98turbls1's Avatar
Some people tap into the vacuum hose between the engine and the brake booster....
Old Dec 29, 2005 | 02:19 PM
trtturbo's Avatar
You can also put a nipple on the other side of the pressure switch the kit comes with. That is usually the easiest when doing the STS kit.
Old Dec 29, 2005 | 02:34 PM
JD_Z28's Avatar
thanks you guys for the info.
