Track times for my turbo setup...
Long story short, this car is mainly only good for freeway rolls, as it has no traction what so ever.
heres the timeslip.
60' 2.047
330' 5.414
1/8 7.872
MPH 104.07
1000' 9.920
1/4 11.60
MPH 135.58
He ran the car on 16 in et streets at 30psi.
heres the video.
this was done on the 101 octane run, which was 947 rwhp. however he said that the tires were not hooking at all, he couldnt even get traction to help the mph out.
Click here to watch Track-run
He believes it would have been over 140 if I had any type of traction.
Let me know what you think.
if you drop that 60' down and lower the pressure in the tires a ton then i would imagine you would have a lot better times.
I'm sure you'll get it dialed in.
like i said, he said it was making so much power that it wouldnt even grab for a while.
he thought that it would actually be better on 12 lbs since it will have more traction.
Drop the pressure down to 14ish as already stated and I bet it will at least hook a LOT better than it is now. 30#'s???? WTF?
WTF?? Good question. Same ole thing people assume things before popping off. A 4000lb car with with 15psi is a DEATH TRAP!
