Problems with turbo kit STS need help
Old Jan 6, 2006 | 12:23 PM
JD_Z28's Avatar
Default Problems with turbo kit STS need help
I just installed an sts kit and I started it up and oil is leaking from the turbine area? I don't have the exhaust tip installed yet so I could see oil pouring from the turbine. What could be the problem, the oil pump works I tested it, what could be flooding the system.
Old Jan 6, 2006 | 01:10 PM
ddnspider's Avatar
It sounds like oil is pushing past the seals...ie too much oil pressure.You need some sort of restrictor in the oil feed line to lessen the oil.many people use a nitrous jet.
Old Jan 6, 2006 | 01:15 PM
trtturbo's Avatar
Make sure the pump is going in the right direction. If there is that much oil, then I am reasonably sure that is your issue.
Take one of the oil return hoses off the pump and see if its sucking or blowing. Turbo side should suck and the pump exit side should blow. If its not, reverse the wires on the top of the pump.
Call me if I can help.
Billy
Old Jan 6, 2006 | 01:31 PM
TaTommyWS6's Avatar
Billy
Exactly. Probably the polarity of the wires...
At least it will be an easy fix!
Tmmy
Old Jan 6, 2006 | 04:45 PM
98Ztwentyeight's Avatar
Default check this too
or he has the center oiling housing upside down!
I did that by mistake and mine leaked quite a bit!
make sure the feed is uptop with the restictor and exhaust or return to the valve cover is on the bottom. I was trying to get it done too fast and spun it all the the wrong way. It leaked pretty bad internally and all I did was let it sit for about an hour after i started it and the return line dumped into the turbo..
Old Jan 6, 2006 | 05:09 PM
WideOpenThrottle's Avatar
It's a common error to put the two wires on top the oil pump backwards! Which makes the pump, pump backwards.
