Sheetmetal intake for FI
Old Jan 7, 2006 | 09:53 PM
422 ragtop's Avatar
Default Sheetmetal intake for FI
Anyone experimented with sheetmetal intake vs. GMPP single plane carb intake and elbow?
I believe I read somewhere that Turbos don't like great big plenums, which this doesn't have.
Putting together Stenod Twin GT 40's, ET 265 heads, Solid roller 388 (4.125 x 3.622).
Can pick this intake up 1/2 off.
http://www.mrnitrous.com/LS-SPYDER%20MANIFOLD.htm
Old Jan 7, 2006 | 10:11 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I've got a Beck sheetmetale intake to try at some point. I want to compare it to a single plane.
One expert said that the results might be the same, but the single plane might have better fuel distribution to all of the individual cylinders. Most sheetmetal intakes like a Beck have some compromise since most folks want them to fit under a stock hood without modifications. In the case of the Beck, the runners are not as long as some might want but as you know most single plane stuff requires either custom elbows to fit or hood and cowl modifications to fit.
Old Jan 8, 2006 | 02:54 AM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
i have a sheetmetal intake i don't think it's that much diff than the single plane. but ill post up some #s as soon i as i dyno my new setup.
Old Jan 8, 2006 | 06:24 AM
422 ragtop's Avatar
I'm going to give it a go as well
It can't hurt to be able to port match this to some ET 265's.
Definately like to see some dyno #'s posted
Brad
Old Jan 8, 2006 | 06:53 AM
422 ragtop's Avatar
Is your friend going to try it?
https://ls1tech.com/forums/forced-induction/433123-my-friend-pretty-busy.html
I'm not a motor expert, but do deal with fluid (air) flow in my line of work.
I don't think runner length should have that much of an effect on FI applications, especially @ 20+PSI. I would think its more about making sure each cylinder gets fed the same. Buy having a plenum feed the runners they should get better and equal distribution.
An elbow directly above the intake cannot be the best. The air will tend crowd the outside radius and potentially starve the front cylinders.
As far as fuel distribution goes individual injectors are still placed at same spot.
I may be all wet....... but dynos don't lie......lets see some results posted
thanks
Brad
Old Jan 8, 2006 | 07:33 AM
Lasershop's Avatar
https://ls1tech.com/forums/showthread.php?t=433123
thanks
Brad
Far as runner length, is veleocity still a factor even in FI setup? Im working on an intake and going to great pains and CAD to maintain long runner length by crossing over the the opposite side before joining the plenum. Also, I have read and researched that plenum volume on FI almost cannot be too large. Bigger the better.
Old Jan 8, 2006 | 08:47 AM
422 ragtop's Avatar
Long runner lengths would help to get air flowing in a laminar (equal velocity across the runner) condition which would be ideal. If you then squeezed the air into a smaller area you would increase velocity with out much pressure (flow) loss. We are trying to optimize getting the air into the head which ultimately delivers it to the cylinder. It is probably more important to port match the head so it can do its job. If the (intake) port is too big or too small you will cause turbulence and create a negative pressure zone which will lower overall flow.
The LS 6 liter truck manifolds have long runners.....great for low end torque....but kill the motor at anything over 5000 RPM.
I agree with you on the plenum volume.....probably only a concern on NA applications.
Keep thinking out loud
Old Jan 8, 2006 | 10:30 AM
aggiez28's Avatar
http://www.proturbokits.com/gallery/...ic=17&offset=9
http://www.proturbokits.com/gallery/...ic=11&offset=9
http://www.proturbokits.com/gallery/...ic=31&offset=9
http://www.proturbokits.com/gallery/...ic=67&offset=0
some decent sized plemuns.... they used to have soem more pics with other larger ones on the site
Old Jan 8, 2006 | 06:09 PM
stevieturbo's Avatar
The larger the plenum, the larger the reservoir of air for any 1 cylinder to draw from, without effecting another cylinder's ability to breathe. Big would appear to be a good thing.
Old Jan 8, 2006 | 10:23 PM
pwrtrip75's Avatar
Ive also read that you should have a larger plenum for FI, I think its Ideal volume should be like 1/3 your cubic inches, or something close to that I forget the exact number. Anyone else hear anything like that?
Old Jan 8, 2006 | 10:32 PM
Quickin's Avatar
Hogan....427....GT55-91mm
Old Jan 9, 2006 | 12:39 PM
