GMR SPEED TT engine bay pics....
Old Jan 9, 2006 | 04:27 PM
Leo@GMRSPEED's Avatar
Suspended Sponsor
LT1 is next on our list We have a huge demand for it with the release of this kit. Hope to have out by spring!!
Old Jan 10, 2006 | 09:00 PM
2000Hawk's Avatar
So if i wanted to get the most power out of a turbo set-up i would choose your twin turbo kit. But if i wanted to keep my accessories such as the A/C i would need to chose the single set-up is that correct?
-Joel
Old Jan 11, 2006 | 09:58 AM
Suspended Sponsor
-Joel
You got it
Old Jan 11, 2006 | 12:30 PM
93formto98T/A's Avatar
Keep those progress pics coming guys. I can't take the suspense!!! lol
Old Jan 16, 2006 | 10:27 PM
Keep up the good work guys, it's looking great.
Old Jan 16, 2006 | 11:02 PM
LSONE's Avatar
Originally Posted by smokinHawk
thats pretty wicked what are you going to do with the heat lines from the water pump right 90's or something?
interested in this aswell
Old Jan 17, 2006 | 05:31 AM
smokinHawk's Avatar
thought they answered it
Originally Posted by Joel@GMRSPEED
Yep, thats what were gonna do. Thanks for the thumbs up on the kit.
Old Jan 21, 2006 | 04:47 PM
Joel@
Guest
Posts: n/a
I thought I would post more pics of the setup off the engine for you guys. These are the hot parts,turbos and wastegates. Will have numbers and final pictures of the whole setup by the end of next week.
Joel
Old Jan 21, 2006 | 05:09 PM
BLWN1's Avatar
Hmm if you decide to sell parts, i would like a price on headers... soon.
Old Jan 21, 2006 | 05:13 PM
dynedta's Avatar
chronic masturbator
this system is well put together as I seen it today very nice hell almost factory looking
Old Jan 21, 2006 | 05:33 PM
That's some amazing fab work there Joel. Can't wait to see what she'll put down.
Old Jan 21, 2006 | 09:13 PM
  #32
flash12t's Avatar
is there any way for u to make it vent to the atmostphere. . ??
Old Jan 21, 2006 | 10:06 PM
  #33
Joel mentioned something to me about making an optional atmospheric dump for the wastegates but I prefer them to exit into the DP's. Is it just me or would the O2's/wideband not get an accurate reading if the WG's dump a good amount of the exhaust gas to atmos.? The O2 bungs are on the DP's at the rear of the engine...
Old Jan 21, 2006 | 11:34 PM
  #34
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
nice nice joel, i can't wait on the finished product. do guys offer anything for the c5
Old Jan 22, 2006 | 01:21 AM
  #35
CAT3's Avatar
Restricted User
Damn, if I can just get over the loss of the AC *he he he it hasn't even been charged since the new shortblock went in*. Starting to conisder putting together a new low comp 402 LS2 or 408 and getting something like this.
1) I am turbo almost dumb, so... The log is facing forward running into the turbo, the WG is piped back into the downpipe (this is the pipe that will run back under the log to the exhaust? How much room is there when on the engine to replace the plugs?
2) Looks like very little, but could be photography tricks
3) Is there sufficient room to use the stock fans?
4) Any pics of the Alternator relocation bracket mounted on the engine?
Anything else need to be moved, or ditched?
Thanks for the time.
Charlie
Old Jan 22, 2006 | 08:41 AM
  #36
Joel@
Guest
Posts: n/a
Charlie
Well we can help you out as much as we can. We like people to know a good amount before they buy one of our turbo setups. So they can understand what there getting and how it works.
The wastegate pipe is the on that comes off the front of the log. Then it goes to the wastegate and out to the downpipe. That is not in the way off the plugs at all. We built the turbo manifold around the plugs, so you can change tem when the setup is on the car.
We use the stock fans with the kit.
For the ALT we will have pics and more info by the end of the week. It does however sit on the passenger side head.
Noting else needs to be relocated or ditched for the setup. That was our goal, to not have to go threw alot of stuff to put this on. Hopefully you all will enjoy the numbers as long as the price.
Moparnos (The SLP Guy) Thanks!!!
Thanks Joel
Old Jan 22, 2006 | 09:48 AM
  #37
solobaric's Avatar
Can I ask what you guys would charge to intall this kit?
Old Jan 22, 2006 | 01:37 PM
  #38
MY99TAWS6's Avatar
I have some interest in this kit.Talking single kit.
Do you think it would clear kenny brown double diamond subframe connectors? I guess downpipe could be tweaked locally if need be.
Also it looks like a very tight fit at sway bar in the one picture.Will it clear a fatter hotchkis front sway bar not sure exact size of my sway bar.
Also you don't mention what the base kit can support at approximately what boost levels although did see the 400 or so rwhp at 5psi.
You are charging the extra 500 plus for various upgrade turbo options or are they same price for most of them when you get intial kit so normally the bigger turbos cost the same as smaller ones except for ball bearing ones and these appear to be no ball bearing and I assume require no water cooling.
Are these garrett or turbonetics.Not a fan of turbonetics more a garrett guy.
Old Jan 22, 2006 | 06:33 PM
  #39
Joel@
Guest
Posts: n/a
Im pretty sure it will clear the KB sfc. The sway does clear on the kit with the shim that we provide for you. We can offer you more spacers if needed to clear your swaybar. As for the turbo upgrades. When you buy the single kit you get the T-60 precision turbo. If you want to upgrade the turbo the prices are on our website. The prices shown are what extra you have to pay to get that turbo posted. The turbos are all garrett internals.
The install price had not yet been determined as of yet. I can give you a somewhat idea....it will be around $1000 to $1800. Will have a better idea later this week.
Old Jan 22, 2006 | 08:47 PM
  #40
MY99TAWS6's Avatar
Also how is this kit for ground clearance.Car is dropped about 3/4 to inch max with slp eibach firehawk springs.
