GMR SPEED TT engine bay pics....
Old Jan 7, 2006 | 10:00 PM
Joel@
Guest
Posts: n/a
Default GMR SPEED TT engine bay pics....
Here are some pics with the cradle and engine in the car. Fits very nice in the engine bay. The turbos are T-61 with a 70a/r S-compressor cover, with 4" in and 2 1/2" out. Theres going to be a FMIC with the kit too. Price is going to be $6699 for the first 10 when released.
Old Jan 7, 2006 | 10:07 PM
white&black96z's Avatar
does this kit let you keep your ac.
Old Jan 7, 2006 | 10:29 PM
ABeasst's Avatar
dont you think oil drain back is going to be a problem with them mounted that low?
Old Jan 7, 2006 | 10:36 PM
Joel@
Guest
Posts: n/a
The kit does not let you keep the a/c . If you need a/c check out our single kit.
The oil drain back is gravity feed. We have not had any proplems on it with our single kit. The turbos are also higher then the oil pan. We didnt want to use scavanger pumps on the kit.
Old Jan 8, 2006 | 02:51 AM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
this is what i wanted to see. looks tight, when do you expect to have it done
Old Jan 8, 2006 | 10:18 AM
bluecamaroz28's Avatar
Very sweet.
Old Jan 8, 2006 | 05:12 PM
black_z's Avatar
That looks frickin awesome.
Old Jan 8, 2006 | 05:33 PM
Joel@
Guest
Posts: n/a
Thank you.We try our best.
Old Jan 8, 2006 | 05:58 PM
smokinHawk's Avatar
thats pretty wicked what are you going to do with the heat lines from the water pump right 90's or something?
Old Jan 8, 2006 | 06:46 PM
Joel@
Guest
Posts: n/a
Yep, thats what were gonna do. Thanks for the thumbs up on the kit.
Old Jan 8, 2006 | 07:49 PM
Order 66's Avatar
Very nice looking kit.
Old Jan 8, 2006 | 08:33 PM
BLWN1's Avatar
How large of a turbo will fit? are you going to offer the headers seperate of have you decided? I would consider a set to piece a kit together as my buget allows....
CP
Old Jan 8, 2006 | 08:52 PM
Tiago's Avatar
Sell hot parts
Old Jan 8, 2006 | 11:14 PM
93formto98T/A's Avatar
Leo mentioned in another GMR thread that they will release hot parts price after the twin kit is released for sale.
Old Jan 9, 2006 | 12:06 AM
SSilverSSurfer's Avatar
sweet set up for the haridryers....looks bad ***
Old Jan 9, 2006 | 10:46 AM
RealQuick's Avatar
Nice work Joel.
Old Jan 9, 2006 | 10:59 AM
NemeSS's Avatar
what size are the wastegates and what brand?
also what size is the FMIC?
Old Jan 9, 2006 | 11:01 AM
NemeSS's Avatar
also can we get pics of the downpipe plumbing/what size?
is a tubular k-member required ?
thanx
Old Jan 9, 2006 | 11:35 AM
Joel@
Guest
Posts: n/a
The wastegates are 44mm Tial gates. The intercooler is a FMIC. The core size is 3.5 thick, 12 wide, and 28 long. It uses the stock k-member, no need for a tubular. The DP are 3inch on both sides.The biggest that we have tried so far is a T-67. You have better have a engine to hold up to 2 of those..
Realquick----Thanks
SSsilverssurfer---Thanks
Order66--Thanks
Old Jan 9, 2006 | 12:11 PM
TurboZ28's Avatar
Any LT1 options in the future?
