Which Turbine Housing?
Old Jan 12, 2006 | 01:44 PM
Cld12pk2go's Avatar
I would say get a Pair of MP T62s, which should be a much better match for your engine for 1000 hp (crank or rw?). I would go with 0.58 or 0.68 A/R p-trim turbine housings if you want boost prior to 3500-4000 rpms.
Old Jan 12, 2006 | 01:48 PM
turbocuda's Avatar
The t-61's flow 65 lbs/hr a piece at 2.0-about 2.8 pressure ratio at 60% eff.....plenty for about 1300hp....with 427....would probably go to .84/.96 turbine ar...depending on what kind of revs.
