Powerdyne Has A New Owner!!!
We always wondered if backpressure was making the belts break, from not venting the extra air under accelerating??? Mine worked flawless when I had it, and the people I know had good luck with them. The guy I got mine from had under 100 miles, and the belt snapped.. With the belts being accessible, for a 5.0 I would hesitate, on the LS1 I dunno about it as I have no experience.
chronic masturbator
Originally Posted by Cannons
It can't be put on a f-body w/o a problem? Why not? I took a BD blower off my truck and directly fit a XB on it. I interchanged them and I didnt have to do anything different.
Originally Posted by dynedta
the truck bd and the f-body bd are different the f-body impeller is reverse rotation
Sometimes Its people who put smaller diameter pulleys on them and rev them past the recommended limit.
Originally Posted by skunk50
people overspin the hell out of Vortec headunits all the time. even mild overspin they don't have problems like the Powerdynes.
Also sorry to say, but Sam is no longer with powerdyne and passed away a little over a year ago.
THERE IS A BIG DIFFERENCE!!! Powerdyne "BD" has a Internal Belt driven system, Vortec is Internally Gear driven. That is why you cant "Over-Rev" A powerdyne past its recommended RPM, if you do you will almost always shred the belt. The ratings of gear driven blowers are rated way lower than what it will actually do. If they advertise 8000 RPM MAX impellar speed, then the speed where they find the blower will fail is at 9000 RPM.
60l, automotive, bearings, belt, driven, gear, injectors, lancasterca, masterbator, masterbators, max, owns, powerdyne, products, recommend, rpm
