Just got the car in today...
Be careful, that's a lot of power for someone not use to it!!!
I guess it is worth trading in my ls1edit for HPT?
it edits the pcm and can monitor live settings too right?
Im sure it cant be something too bad if it was tuned by allan.
Hopefully it has nothing to do with the tune because of the temperature change from LA to AZ.
I called up Allan and he said it should be fine once I put some more water in it, guess it was short on water.
That car is a blast though!
-2 TIAL 46mm wastegates
-TIA 50mm bypass valve
-Griffen intercooler
-FMS custom tubular headers and downpipe(coated)
-intercooler tubing, couplers, clamps, misc. flanges and fittings
-upgrade to GT55/91, turbo - good to 1500 HP
-PA k-member
-Fuel system - RC Engineering 75lb injectors
-Aeromotive Eliminator pump
-Aeromotive fuel filter
-Aeromotive regulator
-Hi-flow fuel rails w\fittings
-fittings and braided hose
-new '98 tank..sumped
heres the motor stuff...
New GM 6.0l block(bored\honed\decked\cleaned)
-Callies 4.00” 4340 crank
-Custom Diamond boost pistons
-Manley Pro-Billet rods
-FMS ported oil pump
-ARP main studs
-Rollmaster double timing chain
-FMS custom hydraulic cam
-FMS pushrods
-Melling hydaulic lifters
-FMS stage 3 heads AFR heads
-Manley 2.100"\1.60" custom valves
-Crane 1.46” dual springs
-Comp titanium retainers
-Comp spring locators
-Cometic head gaskets
-ARP L-19 head studs
-misc gaskets
-New GM lifter guides, cam plate and misc bolts
-assembled\balanced\blueprinted longblock
-port match intake to heads
-F.A.S.T. LSX 90mm intake & throttle body
-Strange 12 bolt rearend & w/back plate
-Upgraded trans - upgraded syncros, carbon blockers, steel shift fork
The FMIC is flush with the air dam.
As far as clearence is concerned, I thought the Waste gates were a little low, but im not worried about that so much as with the 4 in piping out the back.
The lowest part of the ride is the magnaflow muffler, which is probably close to approx. 2 inches or so off the ground.
The good thing about it is that because its towards the middle of the car, its not quite as bad going over speed bumps and stuff since it has room to travel, but Ive scraped it a few times already just driving around, so it is kind of touchy.
I was able to go out and get some video footage of the car.
It turns out the AC was on and I believe that is why it overheated.
Now that I was able to actually drive the car and not be on a specific schedule due to work, I was able to get a good feel for the car.
The car has amazing drivability characteristics.
I can control when i want to get in boost, and am starting to be able to control part throttle runs while in partial boost.
If I do floor it the RPMS jump up so fast its hard to shift at red line without being worried about hitting the limiter, but im getting the hang of it.
Car pulls very fast from a 3rd gear pull.
On monday I plan on cleaning up the car, getting some pictures and posting up an edited video with hopefully getting some day time video too.
So far though after reviewing last night's escapades, you can definately hear the spool and BOV in the video, so you guys wont be disappointed.
Lookin good.....
lol, sorry about that, i just copied and pasted from what allan put, yes it is a TIAL.
So what are your coolant temps driving around? Have you logged anything yet?
Temps last night out side was probably close to mid 50's, low 60's though, so im sure that helped.
As far as clearence goes, ill get some pictures probably on monday.
From what I could tell, it looked like he tucked the exhuast as high and close to the body as possible, I guess 4 in tubing is just a little bigger then id expect.
When i get the pics up you'll see what Im talkinga bout.
You might want to get HPTuners in case you want to tweak anything.
I'd like to see some more new pictures when you get a chance.
Peace,
Josh
I plan on getting some pics and more video of it on monday since I wont have work.
Peace,
Josh
Im hoping it will provide me years of pleasure, but when I start hooking, im sure things will start breaking.
When Im checking over the clamps and stuff, am I just looking for possible leaks, or anything in particular?
