Methanol injection?
Old Jan 16, 2006 | 05:35 PM
clemsondave's Avatar
Default Methanol injection?
Ok, probably one of those stupid questions that everyone knows except me. I see methanol injection as an option for the STS system. What does it do and do I need it?
I will be running everything stock except STS, #42s, Walbro pump. No IC.
Old Jan 16, 2006 | 06:03 PM
Frost's Avatar
PM sent
Old Jan 16, 2006 | 06:09 PM
jcfreak's Avatar
I would highly suggest you get it. It cools the intake charge. It allows you to run more boost and timing. It prevents detination and you can make alot of power. As much as 80hp depending on the application.
Old Jan 16, 2006 | 06:10 PM
Thanks! Frost kindly pointed out that it is in the FAQ. Funny, I did a search and nothing came up. Guess the search does not look at the faqs.
Old Jan 16, 2006 | 06:21 PM
Frost's Avatar
It isn't looking at much of anything apparently... A search for GMR on here netted 2 results...
