STS Turbo Question.
Old Jan 16, 2006 | 05:58 PM
JD_Z28's Avatar
Default STS Turbo Question.
How much hosepower is the stock turbo with the sts kit good for.
Old Jan 16, 2006 | 06:02 PM
jcfreak's Avatar
The turbo on that kit is rated at 650 chp. Thats whats on my truck.
Old Jan 16, 2006 | 06:04 PM
myws6istheshiznit's Avatar
most guys get the gt67 upgrade i read alot about the stock turbo dumping at the top of the rpm range.as for your question i think it can make a little over 600 the 67 is good over 700.on a stock motor at 5psi you gonna be making about 415 maybe. hope this helps
Old Jan 17, 2006 | 03:25 PM
SSnakekiller's Avatar
GT67 is good for 750 chp, if you plan on 700rwhp you may want to consider a GT70, although the 67 should get you close ...but at 700rw will not be completely efficient.
