novi with J- bracket (SD spring tensioner?)
I am making a J-bracket for my Novi 2000 supercharger.
It will mount in the same location as the procharger P1-D1 head units.
I will be using a spring loaded tentioner and ideler pulley just like the SD-concepts 8 rib J-bracket.
OK i need some help and i need to find out a few things.
1) With the ATI LS1 super damper does it matter what size supercharger crank pully i should use, SD-concepts supplies a 7.25 pulley and Procharger sends you a 7.5 ,
2) I would like to know where to buy the same spring tentioner , who makes it? etc.
3) what size tentioner pulley and idel pulley is being used by SD-concepts.
Please help me out
any info will be very usefull
Thank you very much
Please help me out
Thank you very much
Please help me out
Thank you very much
Please help me out
Thank you very much
Please help me out
Thank you very much
Please help me out
Thank you very much
2) I will try to find out for you ASAP.
3) I will try to find out for you ASAP.
I hear the SD-concepts is a Ford spring tentioner see if you can get me a part # for it
also the size of the idel puley in dia, and width
thank you very much
thank you very much
Preferably something that tensioned in a clockwise direction, although I could probably work with either.
