Should I get BLOWN!?
Old Jan 20, 2006 | 11:54 PM
00transamnh's Avatar
Default Should I get BLOWN!?
Im contemplating purchasing a procharger at the moment... im new to fi.
Other than blowing my rear-end what are some hidden costs that im not thinking about/ know about. EX bigger injectors? clutch? etc etc
Will my stock internals hold up?
Old Jan 21, 2006 | 12:19 AM
9silverbird8's Avatar
Fuel pump, injectors, gauges, new plugs, a tune........I'm sure I missed some too
Old Jan 21, 2006 | 03:57 AM
todd4168's Avatar
sure its fun
Old Jan 21, 2006 | 04:47 AM
EPP's Avatar
EPP
Smile
Here is a list of items that I recently put together for building up the chassis prior to adding the horsepower. People are always asking the question of whether to go with a head and cam package, or go with a supercharger or turbocharger. There is no way you are to match the power of an ATI ProCharger with a head and cam package unless you use a pretty radical camshaft. Nitrous oxide could be used instead of going the forced induction route, with very good results at a fraction of the cost. A cold air kit would be required if you elect to use nitrous oxide instead of going the forced induction (ATI ProCharger) route. The ATI ProChargers come with a K&N cone filter. With forced induction, such as the ATI ProCharger, the power is always going to be there when you want it, with no nitrous bottles to constantly refill. A turbocharger could be used instead of an ATI ProCharger, but I am not convinced that the turbo kits currently out on the market will stand the test of time. TurboChargers go through extreme heat cycles, which can fracture the turbo housing mounts.
With the items listed below, your car would be quite capable of routinely running low eleven second 1/4 mile times, or faster, when combined with the M/T Street radial rear tires.
Everyone has their opinions on what is the best package, and here is mine.
1. Subframe Connectors - Absolutely necessary to keep your F Body from twisting and stretching. I have seen too many of these cars lose their door to fender gaps from having gone too long without subframe connectors. Subframe connectors will make the car handle better, you'll get fewer squeaks and the car will get better traction.
2. Torque Arm - BMR, Global West and Spohn all make torque arms that relocate the front mount off of the transmission by relocating the front mount back behind the transmission. The relocation of the front mount relieves the stress from the tailshaft of the transmission that the torque arm places on it, as a result of trying to contain the rear-end and it's rotational stresses. The stock torque arm is a stamped piece of sheetmetal that has broken apart for many people, and it sometimes takes out the driveshaft with it when it goes. By relocating the front mount of the torque arm behind the transmission, the geometry of the rear suspension becomes much better and really aids in hooking up the rear suspension. While replacing the torque arm, check the transmission mount, as the stock torque arm places a huge load on the mount, and the mount breaks quite often when using the factory torque arm. The adjustability of these aftermarket torque arms allows the user to adjust the pinion angle of the rear suspension which aids in finding traction.
3. Moser 12 bolt - Sooner or later the weak 7.5" Chevy S-10 derived 10 bolt is going to break. I wouldn't waste any money into attempting to build up the 10 bolt, it just doesn't work. There isn't one strong point to the stocker. For those of you with a six speed transmission, the 10 bolt has broken on many M6 cars with stock power. Expect the worse to happen... 3:73 gears in the Moser rear-end is a good compromise, especially when adding a lot of power to the engine.
4. Driveshaft - The stock GM driveshaft have broken for many enthusiast, both the steel and the 3.0" aluminum GM driveshafts are fairly weak. I recommend an aftermarket 3.5" aluminum driveshaft with a 1350 Yoke with a 1350 U Joint. Combined with the Moser 12 bolt with their supplied 1350 yoke, you will have a strong drivetrain.
5. Clutch and pressure plate - I recommend the Spec Stage 3 clutch and pressure plate. Expect some chatter for the first 500 miles, then it will be pretty smooth. I would also add the '01-'02 slave cylinder for the older models, and do the "drill mod" to the master cylinder. Do a search on this forum for the drill mod, and you will see what it entails.
At this point I believe the suspension is capable off supporting a lot of horsepower, and you can go straight to item 14.
For those of you who are dragstrip bound, I would also add a few additional items.
6. Adjustable lower control arms - The aftermarket lower control arms are much stouter, and will not flex like the factory lower control arms. Going with adjustable ones will allow the user to center the rear end in the wheelwell. The stock rear end position from the factory tends to be .5" towards the rear of the car. You really won't notice it until larger diameter tires are installed.
7. Lower control arm relocation brackets - Lower control arm relocation brackets are meant to be used when the car has been lowered, which alters the angle of the lower control arms. We have found that the relocation brackets also help in getting traction in non lowered cars. We use the weld on style that BMR offers.
8. Panhard bar - The factory pan hard bar is pretty flimsy and additional traction can be found by replacing the factory pan hard bar with a heavier duty aftermarket bar. The rear in these cars tends to sit closer to the right side, and by purchasing an adjustable pan hard bar, the rear-end can be centered in the body.
9. Strut Tower Brace - Eliminate flexing in the front end by adding an aftermarket strut tower brace. You will also notice that the car will handle better with a strut tower brace.
10. Battery box relocation - By relocating the battery to the trunk, you will remove a lot of weight off the front of the car and place the weight behind the rear-end, where it will aid in traction. The car will also be able to handle better with the weight relocation.
11. Rear coil spring air bags - By experimenting with adding more air to the right air bag than to the left one, better off the line traction can be found.
12. Adjustable shocks and front coil over springs - We use the Hal QA1 12 way adjustable shocks on our cars. It is easy to adjust these shocks for street use, and then readjust them for strip use by simply rotating the 12 way adjustable dial. The Hal QA1 front coil over springs allows the front end height to easily be adjusted.
13. K member - By replacing the front K member and upper and lower control arms with light weight aftermarket tubular ones, a lot of weight is removed from the front suspension. Since front end weight is removed, better off the line traction and better handling will occur. We have had good success with the BMR parts, and combined with the Hal QA1 shocks and coil over front springs, gives the car a much better chance of getting traction on the starting line.
14. Headers and cat back exhaust - Everyone has their favorites, but we have grown very fond of Hooker and Flowtech headers, and the Hooker and Magnaflow Cat Back exhaust systems.
Flowtech and Hooker ceramic coated headers fit very well, with excellent ground clearance. The Flowtech headers are priced very competitively with PaceSetter headers, yet they install and fit much better. The ceramic coatings go a long way towards keeping the exhaust temps in the pipes, keeping the engine bay cooler and improving internal exhaust scavenging. These two brands of headers will give you 2.5" more in ground clearance compared to SLP headers.
The Hooker and Magnaflow cat back exhaust systems give these cars a good muscular sound that will not drown out your stereo while driving down the road. The exhaust tubing is larger than the stock tubing and is mandrel bent, for better exhaust flow.
For those of you who want it loud. If you are looking for an exhaust system that will annoy everyone around you, the two above exhaust systems are not for you. The SLP "Loud Mouth" cat back is a good system for those of you who want to be noticed. When we have one of these cars on my dyno with a loud mouth exhaust system, everyone around our area can hear the car!
15. ATI ProCharger D-1SC eight rib supercharger - Simply the best and easiest way to get 450 to 500 rwhp out of your car in my opinion, when combined with headers and a good cat back exhaust system. The car will still see great part throttle gas mileage, overall driveability will still be excellent, and the power is always there when you want it. At 8 pounds of boost, the car will be very dependable, and with the twin high flow air to air intercoolers, unleaded premium is all you need to use. I recommend the ATI ProCharger D-1SC "tuner" kit, as the D-1SC can handle future mods much better than the P-1SC. You will need 42 lb fuel injectors, a 255 litre in tank fuel pump, and chassis dyno tuning with the "tuner" kit.
Hopefully this list will help you in your quest for having a quick car! Bob
Old Jan 21, 2006 | 07:02 AM
OperationStorm's Avatar
Thanks for the info Bob!
Old Jan 21, 2006 | 07:37 PM
SSmith's Avatar
Question
Do you really need headers if you install a Procharger?
What horsepower differences would there be stock vs headers?
Old Jan 22, 2006 | 09:13 AM
Bad30th's Avatar
I'd say a lot of that depends on his goals. All that stuff would cost a fortune in addition to the blower - would be great if you're building a track car, but not neccesarily mandatory for a street car. I know lots of FI street cars that don't have an aftermarket K-member or relocated battery, me included.
The Procharger by itself as an entry level step will make plenty of power for a street car (although you will want more quickly, haha) - the other stuff Bob mentioned will just compliment it and make it put the power to the ground better. Might be better to add those things a piece at a time as your wallet recovers.
Things you need to consider with a basic Procharger install :
- bigger injectors, 42# minimum, you should probably go with Mototron 60#
- fan. The ATI fan is a POS, if you live in a warm climate you will need an upgrade. I have the SPAL Extreme 16" fan.
- tune. Tuning is critical to an FI setup. If you plan to do it yourself, read, read and read somemore and then invest in a wideband and a nice tuning software package - I have HPTuners.
- cold plugs - I use NGK TR6 plugs. Colder plugs help prevent detonation.
- gauges - boost and fuel pressure are a couple of handy ones. Autometer makes some real nice ones, lots of the vendors to the right sell them. --->
8-9psi seems to be about the limit for longevity on a stock bottom end (with a reasonable tune). Installing parts isn't what breaks factory rear-ends, it's abuse. Take it easy on the 10-bolt until you have the funds to install a nice rear end like a Moser or Currie - the rear end alone will probably set you back over $2k.
Hope this helps,
Rob (Bad30th)
Old Jan 22, 2006 | 12:26 PM
KrazyWS6's Avatar
Basically what everyone else said, but if you get the D1SC you will have to get an 8 rib ATI Dampner $450 and the pinning kit to pin your crank $120.
Old Jan 22, 2006 | 02:00 PM
peter pan's Avatar
I am new to this forum as I spend most of my time on the Vette Forum. There are many Vettes running PS1C's without changing any internals and getting around 500 rwhp and the DS1C members are all around 550 rwhp without going into the engine and those do add 42 lb injectors. If you want more you will need to be forged and this will wake up a 346 with a DS1C. I stayed stock displacement, 9.2 compression 224 581 lift on a 114 LSA with West Coast blower heads, LS6 intake, LT Headers, Alky injection on the performance side. I put down 731 rwhp and 645 tq. And the power is always at my disposal by pressing down harder on the go pedal. Nothing like FI on a LS1 powered car, they come alive
Old Jan 22, 2006 | 07:11 PM
thanks for the help... however
why new plugs?
Old Jan 22, 2006 | 07:16 PM
detonation is a common side effect of FI, colder plugs are a huge help in reducing it.
Old Jan 22, 2006 | 08:02 PM
JohnnyZ28's Avatar
I have pretty much everything accept for the shocks, k-member, and the ProCharger.
Now, I just need money.
Old Jan 23, 2006 | 01:38 PM
EPP's Avatar
EPP
I feel your pain... Thats kept me from doing many things! Bob
Old Feb 9, 2006 | 09:23 PM
SSmith's Avatar
Question
I have a stock 02 SS M6 all the SLP goodies. Anyway I need to know if I have a D1SC installed with my stock exhaust manifolds will I be leaving power on the table by not installing Longtube Headers? A Procharger installed on a all stock car No Longtube Headers has this been done by anyone? Are you happy with it? Do you wish you would have bought longtube headers and high flow Cats or no cats? I don't really want longtube headers if I can get good power with only installing a D1SC kit. I don't want the issues that come up with installing longtube headers. I want to leave my car's factory exhaust as is but just install a D1SC kit. What would it Dyno at the rear wheels? If I had longtube headers what would it dyno? Thanks for any help.
Old Feb 10, 2006 | 01:31 AM
sebaSS99's Avatar
Cool
Did the SPAL bolt right up or did you have to make any mods?
Old Feb 10, 2006 | 01:51 AM
Drewstein's Avatar
Yes, power will be left on the table. I would say 480rwhp if you were all stock with a D1SC. With the proper exhaust, 550rwhp.
