9.0CR with 10# boost or 8.5CR with 16#
Originally Posted by mahhddgtp
kp: How come the boost levels stay the same during the last 1000rpm of the pull? I thought S/Cs kept putting out boost almost linearly until you stop reving. There must be more physics behind them than I've picked up on.
u put 16psi to a stock short block, it will blow. period.
what is ur goal? that would help everyone guide u in the right direction. compression wont much change ur power, its the boost that will. but typically, 8-10psi is the most people will put to their stock short blocks. u can squeeze more out of it, if u have a really good tune, an ic + meth + 112 or higher. but eventually, it will still blow
