750RWHP: How long will it last???
Old Jan 26, 2006 | 11:17 AM
DarkblueTA's Avatar
Dont detonate or knock and check things regularly and u shouldnt have any major problems.
Agreed.
You could always get "cheap insurance" in a beater car like my 500.00 91 Escort. Not the nicest looking car on the outside, but the interior is nice and it runs very well. I run that around more now then my TA just to keep the miles off the TA
Old Jan 26, 2006 | 01:06 PM
Forced370GTO's Avatar
Originally Posted by TrakDay
Unless I missed something on the GTO board I thought you still weren't getting enough fuel to pull to 6500rpms? I thought you were making 655rwhp?
This is on a built 370 guys.
And I know I said I love my methanol kit, but when I build my motor the Meth will be added as a cooling feature and no longer tuned as hard with the methanol as I am now. Be carefuly like they said and I see no reason why you shouldn't be alright. Hell when I finally bone up and build my 408 I am looking for 750rwhp and then adding spray on top of that...
I think you will be fine!
Yea, i made the mods to the fueling and am hitting the dyno on friday feb 3rd. i am expecting between 700-750 so thats why i posted 750rwhp...
Trakday, remember that i pulled 655rwhp @ only 5600rpm with no meth. Now the meth is in and ill be able to pull to at least 6500rpm... i sshould blow by the 700rwhp mark. P.S. i hope you get your rear rebuilt, i wanna see some tens in ur sig!!
Old Jan 27, 2006 | 01:35 AM
Caveman's Avatar
10 & 11 Second Club
Originally Posted by Forced370GTO
my 04 GTO has recently reached almost 750rwhp on pump gas with meth injection. It is my daily driver and i am worried about being plagued with problems and having to fix my car every weekend. Will my car last as a daily driver? i change the oil every 3000 miles use mobil 1 and check fluid levels regularly... im running 14-15psi on the cam and heads in my sig, will this car be reiable, or am i going to blow head gaskets once a month??? any help is greatly appreciated.
You have a similar setup to my 98 Formula, same cam, big motor. If you race your car things will break with that much power, even if you have a built tranny, good suspension parts and a built rearend. I have had one minor problem after another since I put the Vortech on 2 years ago . Before that the car ran 10.9- 11.1 on the 382 motor and never had any probs for about 3 years. I would not want to drive a 700+ hp car as a daily driver.
Old Jan 28, 2006 | 01:16 PM
TrakDay's Avatar
Yeah I knew you were shutting down early due to fuel... I just thought I might have missed a thread with a new dyno... thats all. Good Luck man!
Plan on building that rear end soon though, I just picked up all my parts from BMR and am just waiting on my gears and Diff now! It should hold the power with the ne wheel/tire combo.
Again, good luck man! Keep me posted!
