What kind of power are you 76mm guys making
Old Jan 29, 2006 | 05:06 PM
RealQuick's Avatar
Default What kind of power are you 76mm guys making
If you guys could post the engine ci, which turbo kit and what turbo... GT42, PTE, turbonetics, etc. that would be great.
Old Jan 29, 2006 | 06:43 PM
nick97ta's Avatar
dont know still not done with the install.
I dont know if you remember me or not.I posted pic.s on fbody.com of my pass. header that I built.if you want me to post more pic.s on fbody let me know.I just got the engine started last night.
Old Jan 29, 2006 | 07:01 PM
RealQuick's Avatar
Yeah bro, I remember you. You got more completed pics now? Definitely post them up here or on fbody.com and post a link on here if you want.
Old Jan 29, 2006 | 08:39 PM
W8N2SQZ's Avatar
My setup consists of stock block filled with piston and rods. It has a set of stock truck heads and a stock cam. It does have an LS6 intake with a home ported TB. Two pumps in the tank, -8 feed, rails, and 60 lbs injectors. First time at the dyno on 8.5 psi it made 515 horse and 540 torque. It is a PTK kit with a 76 GTS.
Since then I have a little bit better tune and I am working on a cut out. We will see what it does.
Glenn
Old Jan 30, 2006 | 08:16 AM
RealQuick's Avatar
Glenn
thanks Glenn. ANyone else? Mightymouse, you ran a T76 for awhile right? Engineermike, get in here with your setup too. Lets make data filled post here
Old Jan 30, 2006 | 12:00 PM
LTLHOMER's Avatar
Local mustang guy went bottom 9's around 155 with a 76. 3200 lbs and it wasn't even a super clean pass. He'll prolly chime in.
Old Jan 30, 2006 | 12:42 PM
RealQuick's Avatar
Which brand turbo did he use and what c.i.?
Old Jan 30, 2006 | 01:23 PM
LTLHOMER's Avatar
302 based motor (331 cube maybe) and I believe a precision turbo but not sure.
Old Jan 30, 2006 | 01:56 PM
Frost's Avatar
I'll have stock-inch LS1 (forged) numbers from a PTK w/76gts to post hopefully in the next 10-14 days...
....would have been sooner, save for the God of Turbo Delay who hath cast his mighty rod down onto... well you get the picture...
Old Jan 30, 2006 | 02:55 PM
99SS-T's Avatar
stock short block Truck heads small cam Phamspeed kit other wise stock with a precision turbo T-76s made 661hp 650 tq at 12 psi on a mustang. GL man
John
Old Jan 30, 2006 | 03:11 PM
RealQuick's Avatar
John
Nice numbers! Was that pump gas?
Old Jan 30, 2006 | 03:39 PM
W8N2SQZ's Avatar
99SS-T, those are awesome numbers but keep in mind he is on a GT42 frame. Completely different turbo. This will be the turbo I am trying to fit in hopefully
Glenn
Old Jan 30, 2006 | 04:37 PM
engineermike's Avatar
. . .Engineermike, get in here with your setup too. Lets make data filled post here
Alright alright. . .
LT1 363 cid, 8.5/1, 5.7 rod, AFR210 race ready's, 224/236-114
T-76GTS, Bell water/air intercooler 22 x 4.5 x 4.5 core, homebuilt kit using a merged 3" log (like the GN's) on the driver's side.
TH-350 with a 2800 converter that flashes to 5400.
13 psi: 575 rwhp
19 psi: 680 rwhp
I know the combination is capable of 750 rwhp at 20 psi through the auto, but I'm working out kinks right now.
Mike
Old Jan 30, 2006 | 05:02 PM
W8N2SQZ's Avatar
PHP Code:
"Alright alright. . .
13 psi: 575 rwhp
19 psi: 680 rwhp
Mike"
NICE!!! all that power through a T350. I bet you are 710ish through a six speed. Good numbers man.
Glenn
Old Jan 30, 2006 | 05:13 PM
Thanks for the prop's, but I bet it would be way over 710 with a 6 speed. I calculated 23% slip at peak hp based on rpm and mph dynojet graphs. Also, check this out:
http://www.turbomustangs.com/smf/ind...?topic=12123.0
The guy lost 220 rwhp by switching from a 6 speed to an auto even after raising the boost!
Old Jan 30, 2006 | 05:18 PM
W8N2SQZ's Avatar
http://www.turbomustangs.com/smf/in...p?topic=12123.0
I actually agree with you, I was just being really conservative. With all of that said...you have a nice set up
Haha, I just read that mustang post. A glide will KILL dyno numbers
Glenn
Old Jan 30, 2006 | 05:23 PM
bboyferal's Avatar
Old Jan 30, 2006 | 05:32 PM
RealQuick's Avatar
13 psi: 575 rwhp
19 psi: 680 rwhp
Mike
Nice Mike. Are those dyno numbers with the 383ci or the new displacememnt. If not with the 383, can you post numbers on the 383 setup.
Old Jan 30, 2006 | 05:43 PM
StoleIt's Avatar
NKAWTG...N
you should consult the boosted lists as well, thats what they are there for.
Old Jan 30, 2006 | 06:01 PM
Oh jeez, now you had to complicate things. . . here's the drama:
Original dyno with 383 cid, Vortech intercooler (3 psi pressure drop), 90 deg miter intake piping, 52 mm TB, unported LT4 intake, and 18 - 19 psi: 680 rwhp.
Later dyno with 383 cid, 2.5x bigger Bell intercooler, long radius intake piping, 58 mm TB, raised runner LT4 intake, 19 - 20 psi, and a washer stuck in the exhaust housing (doh!): 675 rwhp.
Most recent dyno with 363 cid and no washer stuck in the exhaust housing at 20 - 21 psi: 670 rwhp.
Either there's something wrong with my current combo, or the 383 flat-out made more power. Dyno testing has show that 355 cid will make more power than 383 cid with the T-76. That's why I say I don't have the kinks worked out yet and I expect ~80 more rwhp.
Mike
