But then you need LS2-specific injectors and fuel rails right?
Maybe I'll flow my new heads.... whenever they get here.
In order to put the 60# Mototron injectors on my engine, I bought a little kit from Katech that has new O-rings, as well as longer bolts and spacers to lift the fuel rails up. The new-style injectors are shorter than the older ones. Also, my harness is different, and required a set of adapters [these are the same ones that the Cobra guys have to use when they go to bigger injectors].
So: the LS2 manifold is just a tad different, requiring an O-ring. Using LS1 rails and injectors shouldn't be different.
