FI head decisions
Old Feb 7, 2006 | 03:08 PM
Got Me SOM's Avatar
don't know of rick crane but yea lemme know I'll make a trip out and check it out.
you're a 382 turbo right? i forgot the specs on your ride.
Old Feb 7, 2006 | 03:34 PM
stevieturbo's Avatar
I went for a pair of CNC'd Edelbrock heads. Just need to get my finger out and build the damn thing.
Exhaust flow seems to be very good in relation to Inlet, which is one of the reasons I chose them, and I'm still on a stock bore size, as opposed to a larger bore. Some people advised the AFR225's wouldnt perform as well on a small bore engine. Add to that, I didnt think the exhaust port flow on a 225 where that much greater than a 205, in comparison to the inlet flow differences.
Who knows how me Edelbrocks will work in reality though. Well enough I think
And if they dont, they look nice anyway.
The only mention of deck thickness on the Dart heads, is where they said the deck is as thick as it needs to be.
I would say though, that a decent set of heads would be more important to a CF blower car, than in a turbo car.
A turbocharged motor will have the ability to make power regardless of what heads are fitted, due to the simple ability to increase boost pressure.
Obviously good heads will help, but a CF blown car should realise more benefit compared to a stock head.
Old Feb 7, 2006 | 03:35 PM
Wet 1's Avatar
Some light reading for those who don't use the search feature...
https://ls1tech.com/forums/showthrea...8&page=1&pp=40
BTW, the Dart heads only have a .500" deck.
Old Feb 7, 2006 | 05:19 PM
ddnspider's Avatar
GMS....383,yeah thatll be cool,i shoot u an email when it gets closer to tear down time.maybe ud be willing to give me a ride in the beast u got that Norris did. lol
stevie what did those heads flow?
Old Feb 7, 2006 | 05:38 PM
Got Me SOM's Avatar
fo shizzle my nizzle, you take me in yours i'll take you in mine.
Old Feb 7, 2006 | 07:07 PM
ddnspider's Avatar
no prob,when its done id be happy to.What are you making these days?u can pm me if you'd like instead.
to get back on topic,Wet1 had a good post about that other thread(which i posted in and didnt even remember) thats good info.
Old Feb 8, 2006 | 08:06 PM
b727pic's Avatar
Thanks guys all good input!!
Old Feb 9, 2006 | 07:13 PM
LANCE ATKINSON's Avatar
Originally Posted by Phate
LOL, if you want to make power and get quality parts then stay away from ARE/Autoworks.
I dont think I sd go with ARE I was refering him to pete at cnc heads. I know that ARE has a bad rep the only thing of theirs Im running is their heads and I havent had a minutes trouble, Its gonna make around 700rw on 15 psi. That may be low numbers to everyone else but sounds ok to me comparing to other cars! With petes heads and cam and some good headers u'll make around 640 rwhp and 615rwtq on 11psi for about 1850.00! U wont be dissapointed I promise!
Old Feb 9, 2006 | 07:25 PM
Phate's Avatar
LOL, There is/was a Pete at ARE/Autoworx...so I thought that you were talking about him
Good luck with the car...700hp is nothing to sneeze at!
Old Feb 9, 2006 | 10:09 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
CNC Heads = Pete Incaudo.
Old Feb 9, 2006 | 10:55 PM
Thats him! Thanks
Old Feb 9, 2006 | 11:39 PM
  #32
C6Dude's Avatar
Default LS2 402ci AFR 225's 9.5:1 D1SC@15psi
AFR 225's ARP studs and Cometic gaskets
Old Feb 10, 2006 | 11:34 PM
  #33
What kind of power u make man? Im curious what the difference is between ours with ur more cubes and AFRs and ls2 intake. That intake is supposed to be 30rwhp over an ls6 and an lsx on a blower app! I know Im straying from the subject a little but just curious.
Old Feb 13, 2006 | 10:32 AM
  #34
J&J Speed Shop's Avatar
We haven't seen 30 rwhp HP on a blower car with the LS2 intake. Where are you getting this info from?
Old Feb 13, 2006 | 10:38 AM
  #35
ddnspider's Avatar
Theyve tested that the LS2 intake sucked compared to an LS6 intake so why would it all of a sudden be better for a boosted application.
Old Feb 13, 2006 | 10:42 AM
  #36
Cbrakllr's Avatar
if you have an LS1 try LQ9 heads.
Old Feb 13, 2006 | 10:51 AM
  #37
LS1Tech Co-Founder
I'm removing my ported 6.0 heads and going to ported AllPro 70cc Hurricane heads.
Old Feb 13, 2006 | 11:11 AM
  #38
ddnspider's Avatar
how much are you really planning on gaining from the head swap John
Old Feb 13, 2006 | 11:13 AM
  #39
LS1Tech Co-Founder
It's all part of the mix, but generally going to a higher flowing intake makes sense if the heads also flow really well. I'm going from a LS6 intake/tb setup to an Edelbrock single plane and a NW 90mm tb.
Old Feb 13, 2006 | 11:29 AM
  #40
ddnspider's Avatar
ah gotcha....that would/could make quite a diff then.I remember that article in GMTH about the Strictly Performane SS that gained like 90hp from an intake swap with elbow.
