Turbo 201 (I think I am getting it...)
Originally Posted by JZ 97 SS 1500
Yes some of our combos are being monitored. Some quick examples are, 383/396 LT1's with 76GTS's at ~18psi is around 55psi...ouch. 408 LS1 with GT42-76, 18psi was 59psi....ughh. 360 windsor race engine, with GT47-85 at 20psi was around 48. Better but still not good. 402 LS1 with S88 at 18psi was 39, 347 windsor with 101 at 19psi was 21 . Big turbos rule...lol
LS1Tech Co-Founder
You might want to look at some of the info on JZ's site, but you might want to look into a 80-82mm turbo because it sounds like a 76mm might be done at like 6000rpms... Best do some reading!
Thats the thing,i been reading alot lately.As a matter a fact i talked to Jose about my setup and he told me for my 383:
mostly Track:T88
mostly Street:T76GTS
but with the findings lately i guess im just second guessing myself.im happy if the car makes 600rwhp and doesnt have an issues because the turbos too small.Id like to get him on here to explain more.What turbo did u go with PSJ?
mostly Track:T88
LS1Tech Co-Founder
600rwhp should be very easy with any of those turbos. The question I think is whether you are hitting a lot of backpressure between 6000-6500 rpms.
I picked a combo that I hope can make 1000-1100 rwhp.
If you know, what kind of power did the 347W with the 101mm make? What RPM was peak torque reached? Thanks in advance.
-Russell
Rick, I thought most of the turbo combos on here peak at 6000 rpms or so. Where does yours peak? I have a feeling mine is going to peak around 6500, but we'll see.
These particular testing passes on the freeway were strickly to determine how much MPH was being lost to the converter at the top end on the drag radials.
Rick
Now surge comes into play when the turbo is too big? Do big turbos on small import motors surge?
Andrew
LS1Tech Co-Founder
Is that graph on JZ's board showing air/ lbs per minute? If so, what is the baseline for a stock engine? A 414ci LS1 is a nice example but it's a bigger engine than most.
Moderator
John,
Here is an expanded excel spreadsheet showing air requirements of a 346ci LS1 based off the spreadsheet Jose has on his web page. 25psi up to 8,500rpm. I know your not planing on spining it that high but it's a good FYI for you. http://73-ls1.com/misc/Airmap.xls
#32
You shift at 6300 or higher?
I suspect there have been very few surge issues for our motors and the turbo combos that we've seen to-date. It would be a street problem most likely.
In the world of diesel trucks, you'll run into the fun of "Turbo Bark". We're talking big cubes, 32-40PSI+. The motor not only refuses to take that last gulp of air but the air charge actually causes the compressor to shudder stall making a nasty sounding bark. It's not the most pleasant sound when getting off a freeway pass.
Rick
#35
Originally Posted by LIL SS
John,
And yes i'm serious about 37 and 9000
#36
Moderator
Depending on boost level, these are my requirements lb/hr
1st gear shifting at 8k / 10psi I only need 77lbs
begining of Second (5,400rpm) 10psi I need 52lbs - 77lbs at 8k
begining of Third (6k rpm) 10psi I need 58lbs - 77lbs at 8k
begining of Fourth(6,200rpm) 10psi I need 60lbs - 77lbs at 8k
So at 10psi I will never need more than 77lbs at 8k.
1st gear shifting at 8k / 25psi I only need 126lbs
begining of Second (5,400rpm) 25psi I need 85lbs - 126lbs at 8k
begining of Third (6k rpm) 25psi I need 94lbs - 126lbs at 8k
begining of Fourth(6,200rpm) 25psi I need 95lbs - 126lbs at 8k
So at 25psi I will never need more than 126lbs at 8k.
This is based off the stock airflow of an LS1. I would assume that these numbers would be higher with a better set of heads, intake and exhaust as the air flows much easier.
The PT91 I plan on using should support in the 135lb/hr range.
