Guys with 15+PSI on D1-SC... 1 Question
I have a w2w blower motor (8:1 compress.) running C10 fuel. What is the MAXIMUM amount of boost you can run on a D1-SC WITHOUT hurting the blower? I'd love to run 15+ PSI but I heard 15psi was pushing the limits of the blower if I'm going to run at the track every weekend?. I have a COG setup so im not worried about belt slippage. Could I run, perhaps, more than 15+? I have no experience past 11psi and dont want to find out the hard way. This is a low 10sec car. Anyone experiment with this? Any and all help is appreciated.
Jay
When using cog pullies try to use a drive that allows for a large blower pulley. At rpm the heavier cog belt likes to "grow" over the top of a cog blower pulley and it can strip its teeth if it looses root contact with the pulley.
If you have the stock intercoolers and swap to a bigger front mount that will give you a little more boost along with taking the plastic air filter elbow off and making a screen for track use. I pick up nearly 2psi at peak by removing the intake elbow but the midrange boost doesnt really change a whole bunch - looks good on the dyno but doesnt make the car go a whole lot quicker so I leave it on..
Jay
Nice looking setup by the way
Jay
The F1R volute is .750" larger in diameter and the inlet will be moved .625" farther outwards over the F1. So the overall depth of the F1R would change approx .850" over the D1SC.
Hope that is useful.
Any increase in parasitic loss from a steeper stepup ratio is usually offset by greater belt wrap in a serp type drive resulting in higher boost from a given pulley combination and longer belt life when you're pushing it hard. Belt wrap is also important for a cog system, many don't realize that.
In your particular question you posed the F1 flows a bit over a 100 cfm more than a D1SC so the airflow increase would only result in 2-3 psi more. The F1 might be a touch softer on the low end, but not for long.
