Supercharged Ls1 Help
Old Feb 9, 2006 | 12:08 PM
ItDoRun's Avatar
Default Supercharged Ls1 Help
I'm in the process of convincing myself to do an LS1 swap in my '68 Camaro and would like to, eventually, put a supercharger on it if I do the conversion. My thoughts are to buy a used LS1/T56 combo for the conversion. My question is do I need to do anything special to the internals of the motor in order to run a supercharger later? I would like to obtain 450-500 hp. Please advise.
Thanks,
Chris
Old Feb 9, 2006 | 02:14 PM
Bikeboy1's Avatar
Motor handles 450-500 Hp pretty easily with a proper tune. Add rod bolts and forged pistons for extra peice of mind.
Old Feb 10, 2006 | 05:13 AM
EPP's Avatar
EPP
It will make your life a little easier if you start with a 99 - up drivetrain for your '68. The computer for the '98 is different, plus the heads use a perimeter style pattern for the valvecovers, and the coil brackets are different.
For the power level you are looking for, 8 psi of ProCharger boost and stock internals in the engine will be just fine. That '68 will fly!!! Bob
Old Feb 10, 2006 | 06:46 AM
2001WS6Vert's Avatar
Since you've got the engine out I would at least put in forged pistons. That buys you a lot of insurance.
Old Feb 10, 2006 | 03:21 PM
ItDoRun's Avatar
Thanks guys. I was definitely planning on puting another cam in the motor before I installed it in the car. If 450-500 hp is achievable w/out a supercharger, I would like to try without first. What kind of motor mods should I do to get in this range? Like I said, I was planning on a new cam anyway (something with a little bump!...since this car is from the vintage era). Give me some recommendations on something that won't make the computer go crazy everytime I start it up.
Thanks,
Chris
Old Feb 11, 2006 | 05:40 AM
EPP's Avatar
EPP
Here is one route you could take.
Starting with a LS2 engine will give you a larger cubic inch displacement, and a stronger block, due to the siameized cylinder bores. Add a 4.00" stroker crank and you will have a 402. We use the Callies Racemaster crankshafts on a lot of our builds, along with Callies compstar connecting rods, and Diamond pistons. I'd shoot for a compression ratio in the 10.0/1 range, which will allow you to add an ATI ProCharger with 12 lbs + of boost in the future, if you choose to.
You will need an aggressive camshaft for the power that you are looking for. Something along the lines of the T Rex camshaft. It will have to be a thumper to make the power N/A, but with good tuning it will idle good.
Cylinder heads will make all the difference in the world. I'd go with a pair of AFR 225's, or something similiar in flow.
I'd use a FAST 90mm intake and a Nick Williams 90mm throttle body. Bob
Old Feb 11, 2006 | 07:34 AM
chuntington101's Avatar
bob, what do you think is the most you could get out of a 402 on good pump fuel N/A?
doesn't have to be that torque, just good power!
i habe seen 377ci small bolcks making around 700bhp! is this doable?
Chris.
Old Feb 11, 2006 | 07:56 AM
EPP's Avatar
EPP
I've seen 382's make just under 500 rwhp on my Mustang Chassis Dyno, so it is feasible to imagine that a well prepped 402 could make 525 to 550 rwhp, which would be up there in horsepower at the engine. Bob
Old Feb 11, 2006 | 09:00 AM
Got Me SOM's Avatar
450-500 flywheel hp is plenty achievable with ANY type of forced induction with very safe boost levels on a stock engine. 6-7 psi. Here's the stickler, you'll want more power after a while.
ultimately you are ruled by your wallet.
1st gens with LS1 motor/drivetrain are the best of both worlds.
