Is the only difference between a TT and a T set-up.....
Old Feb 17, 2006 | 09:51 PM
  #41
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'd think that two smaller wheels are lighter than one big wheel.
Old Feb 17, 2006 | 11:56 PM
  #42
Quickin's Avatar
Just going by PurEvl's setup with a 408 T88 Turbo setup I would hate to do aggressive driving on the street with it ussing an A4 unless it had a manual valve body. This is why. The car is very drivable and it's easy to control traction with throttle control but if you hit it to the floor it will spool and blow the tires off,nail the rev limiter -even at 90mph (Nitto 315's) .Now take an A4 in drive. You go heavy from a stop light,the Turbo spools and the next thing you know the speedo is pegged because it went through the gears.So your going 60mph but the tires are going 180mph.This makes the car hard to control if it decides to go sideway's because the tires have no chance of grabbing while they are spinning that fast. Sometimes it is still fun though.
I wouldn't ever spin them and juist stay on it. I would certainly get very well aquainted before I really got aggressive. My car now can spin them for 100 yards easily but I never do. Its the hit a FI car takes when the boost comes in that I'm wondering about. It would suck if it just comes out of nowhere and is out of control.
Originally Posted by Slowhawk
When you do 800-900rwhp you will think the car is slow then too after you get use to it
Thats why the goal is much more than that
Old Feb 18, 2006 | 02:32 AM
  #43
Mike 01WS6's Avatar
This thread, started by the same guy that wanted to take off his rear brakes (ditch the rotor and caliper) to free up RWHP during roll-ons on the street.
The logic is of none I've ever seen before. Every post seems to carry it. I'm sure ******* glad I don't have you on the roads in MY state......I'd move.
Old Feb 18, 2006 | 02:49 AM
  #44
LIL SS's Avatar
Moderator
I can agree with this, but I still go back to the fact you have less exhaust to turn those 2 smaller wheels. I wonder what the actual difference is between say a 91mm's rotaional weight on the compressor/shaft/tubine vs and twins of the equal flow. But then we would also have to figure out the heat loss in the piping for the single and the turns in the exhaust too.
Old Feb 18, 2006 | 07:09 AM
  #45
Slowhawk's Avatar
LS1Tech Sponsor
Turbo's are weird though. The best way to explain it is that they hit like Nitrous sometimes. Boost can come out of nowhere when it shift's under load kicking the car sideway's a bit.Nothing bad,kind of like a built GN.
BTW- everybody say's they will make huge power Buy a new block since the one you have won't take it
