boost limitations 30+psi?
Old Feb 11, 2006 | 02:09 PM
spanktu's Avatar
Default boost limitations 30+psi?
anyone here run in excess of 30psi
on a LSx motor yet?and I am not talking on a stock motor.
just curious with the block design and only having 4 bolts per cylinder
if anyone has run this kind of boost
Old Feb 11, 2006 | 02:32 PM
LTLHOMER's Avatar
w2w has done it for sure. Talk to those guys...Harlan also got very close to 30 lbs I recall.
Old Feb 11, 2006 | 05:06 PM
smokinHawk's Avatar
ohio boys do on there fomula, maybe on the CE
i know on the formula they push water past the gaskets and have to refill it on every pass
Old Feb 11, 2006 | 05:51 PM
spanktu's Avatar
how much boost are you running smokin?
and what kind of head gaskets are you using?
Old Feb 11, 2006 | 07:53 PM
Stenod's Avatar
LS1TECH Sponsor
we have on a few cars
Old Feb 11, 2006 | 07:58 PM
LASTLS1's Avatar
6 Second Club Moderator
Whit 1/2 inch studs and a good tune what's the magic number before you lift them?
Old Feb 11, 2006 | 09:32 PM
427's Avatar
427
We have been over 30psi on a few runs. We see compression leaking into the cooling system that seems to start as we exceed 1200ft lbs. I will be running a couple more test runs on my engine soon that may help the learning curve.
Kurt
Old Feb 11, 2006 | 10:47 PM
smokinHawk's Avatar
right now im running 0psi with cometic mls gaskets.
hope to be changing that soon as soon as i figure out how to start my hooptie
Old Feb 11, 2006 | 10:56 PM
422 ragtop's Avatar
Kurt
Kurt:
Do you have any flow data for heads @ 1 and 2 bar and above?
Amount of PSI req'd to make X HP depends on motor size, motor RPM, heads, cam etc right?
A motor with stock displacement, stock heads etc may take 28 PSI to flow enough mass to make 1000 HP, where a well breathing set-up may make the 1000 at 15 PSI.
I know have heard many times that there is no need to worry about head flow in big boost applications, but it has to have some effect.
Billy (W2W) is building a short block for me and I am trying to figure out how fast I need to spin the motor to make X HP with X boost
Brad
Old Feb 12, 2006 | 08:50 AM
1dirtyZ's Avatar
what ever happened to the 18 psi limit befor lifting the heads?
from what i'm getting, if you have arp studs ( not the 1/2 inch ones) you can go above 18 psi?
does the cam play a role in setting the upper psi limit ( the whole cylinder pressure thing and cam profile)?
Old Feb 12, 2006 | 09:15 AM
smokinHawk's Avatar
that was a robo thing. with a poor designed turbo kit or bad tune perhaps
it seems once the ohio boys got their formula running with a well designed turbo kit (T6 framed) and a good engine management system, the ls1 turbo world took off.
they do push water out so they seem to be lifting some at their 1300+rwhp level, but what do you expect. They can run rounds with their engine so its no big deal, their w2w motor seems to be holding up quite well.
Old Feb 12, 2006 | 10:29 AM
427's Avatar
427
No flow data @ 1 and 2 bar or above.
Generally yes.
The ability to move more air is what makes more power, so a properly built larger engine will have the ability to produce more power. This assumes the engine is mechanicly sound when it gets big.
The ability to move more air is always good, within reason.
The amount of psi is a bi-product of forced induction. Size your power adder to move enough air for your power goal, the psi will be secondary.
Kurt
Originally Posted by 422 ragtop
Kurt:
Brad
Old Feb 13, 2006 | 05:18 AM
1dirtyZ's Avatar
so the fact that you need a thicker deck surface on the head is some what irrelavent?
and what about on a supercharger setup?
